CCS getting started with pic 12f629
Sebastian20000
PostPosted: Fri Nov 09, 2007 2:07 pm     Reply with quote
I´m a rookie in using pic controllers and even the simplest program
doesn´t work. For testing i only want to set high the Pins A0, A1 and A2,
but when I connect the pic to the demo board nothing happens.
(I am using the pic 12F629)
I hope you can give me a small start hint:
((.c data:))
#include "C:\Dokumente und Einstellungen\Sebastian.SEPPEL\Eigene Dateien\pic\test2.h"
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
OUTPUT_HIGH(PIN_A0);
OUTPUT_HIGH(PIN_A1);
OUTPUT_HIGH(PIN_A2);
((.h data))
#include <12F629.h>
#FUSES LP //Low power osc < 200 khz
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES BANDGAP_HIGH
((standard 12F629.h))
Thank you very much!
PostPosted: Fri Nov 09, 2007 2:19 pm     Reply with quote
#FUSES BANDGAP_HIGH
Look at the comment on the oscillator fuse setting.
You need to change it to: INTRC_IO
Sebastian20000
PostPosted: Fri Nov 09, 2007 2:27 pm     Reply with quote
you mean instead of :
#fuses INTRC_IO
can you explain what is the effect of this fuse?
I don´t find it in my manual...
quote: Thank you veryy much :-) it works
PostPosted: Fri Nov 09, 2007 2:40 pm     Reply with quote
See this thread for an explanation:
http://www.ccsinfo.com/forum/viewtopic.php?t=31698
Sebastian20000
PostPosted: Fri Nov 09, 2007 2:50 pm     Reply with quote
ok, i got it.
stupid fault
