MCP3021 don't work!
Doglao
MCP3021 don't work!
PostPosted: Wed Oct 31, 2007 10:11 am     Reply with quote
Hi there!
I make a code to comunicate with a i2c mcp3021 device but it don'work!
what's wrong with my code?
struct DoisBytes
   int iLsb;
   int iMsb;
union Junta_dados
   int16 Total_ad;
   struct DoisBytes Msb_Lsb;
}Valor_ad;
int lsb;//varialvel do byte baixo do mcp3021
int msb;//varialvel do byte alto do mcp3021
//*AUTHOR Douglas Ricardo Dos Santos Pereira
//*PURPOSE Le o expander mcp23016 suas entradas
//*DATE_CREATED 01/06/2006
//*CHANGES
int16 Read_ad(){
   int16 temp_pressao;
   i2c_start();
   i2c_write(0b11011001); //coloca endreco do escravo  e como escrita
   msb   = i2c_read(1); //comando de ler o msb
   lsb   = i2c_read(0); //comando de ler o lsb
   i2c_stop();//finaliza leitura
   delay_us(50);
   Valor_ad.Msb_Lsb.iLsb=lsb;
   Valor_ad.Msb_Lsb.iMsb=msb;
   Valor_ad.Total_ad = Valor_ad.Total_ad>>2; // ajusto os bits
   temp_pressao=Valor_ad.Total_ad;
   return temp_pressao;
and the main code
#include <16F628a.H>
#fuses XT,NOWDT,PROTECT,PUT,NOBROWNOUT,NOLVP
#use i2c(master, scl=pin_a2 ,sda=pin_a3)
#use fast_io(a)
#use fast_io(b)
int16 Valor_pressao;
    set_tris_a(0b00111111);
    set_tris_b(0b00000000);
   setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_64);//timer0 com clock interno e prescaler dividindo por 64
   set_timer0(155);
   lcd_init(); // Inicio obrigatorio
   lcd_setcursor(0,0); // ajusta cursor invisivel e modo fixo
   // TODO: USER CODE!!
   while(true){
      Valor_pressao=read_ad();
      printf(lcd_putc, "%u  ", Valor_pressao);
this is not a precision code to show a converted value, is a very simple attempt to comunicate with mcp3021.
please what can I do to fix it?
Thanks!
Breaking rocks in the hot sun!
Doglao
Wayne_
PostPosted: Wed Oct 31, 2007 10:52 am     Reply with quote
I think you have your bits the wrong way around!
Should be
i2c_write(0b10011011);
Doglao
PostPosted: Wed Oct 31, 2007 11:39 am     Reply with quote
Thanks Wayne_!
I'm going to prove with this change, is need firstly to send the device code as lsb. so! this seam like this:
i2c_write(0b10011011); // first four bits is the device code fallowed by the three address bits
// and finished with a bit that said to device is read or write operation by the master,
very thanks, I return the results
Doglao
rnielsen
PostPosted: Wed Oct 31, 2007 1:37 pm     Reply with quote
I would suggest _not_ using fast_io and not trying to set the tris. Just let the compiler take care of things for the I2C bus.
What is the full part number for the A/D? The address is dependant on the part number. Check out the data sheet thoroughly to see what address to send.
Ronald
Doglao
PostPosted: Wed Oct 31, 2007 1:42 pm     Reply with quote
Hi! Wayne_
is not running yet! I believe that need a delay time more great than the current for each calling to the read_ad function, but I make the changes and not run to.
my circuit is the same that I use with other i2c device that run perfectly
Doglao
Doglao
PostPosted: Wed Oct 31, 2007 2:00 pm     Reply with quote
Thanks Ronald!
I'm using the default address 101 because the part don't was ordered from microchip.com with a special address. this was buyed from a supplier informal , but is not a bad idea to probe with other addresses.
I return the results.
Doglao
Doglao
PostPosted: Wed Oct 31, 2007 6:09 pm     Reply with quote
is not working! I make the changes in the configuration of porta letting the compiler set your configurations and also change all addresses possibles and not working yet.
is my code wrong on theirs commands?
   i2c_start();
   i2c_write(0b10011011);  //coloca endreco do escravo  e como escrita
thanks!
Doglao
PostPosted: Wed Oct 31, 2007 6:51 pm     Reply with quote
Do you have 4.7K pullup resistors on the SDA and SCL signals ?
They are required by the i2c specification.
Doglao
PostPosted: Thu Nov 01, 2007 11:32 am     Reply with quote
Thanks to reply PCM Programmer!
Yes !! are existing pullups with those resistors that you mentioned in both lines sda and scl. and this circuit work well with other device 12c mcp23016 that I use in other project. I think that my code is not reliable with the datasheet recommendations.
Thanks again!
Doglao
rnielsen
PostPosted: Thu Nov 01, 2007 12:12 pm     Reply with quote
Ok. So, post the full part number and the address that you are attempting to write to.
Doglao
PostPosted: Thu Nov 01, 2007 12:53 pm     Reply with quote
Thanks Ronald!
MCP3021A5T-E/OT
the address that I use is 101 that match with the A5 address options of partnumber.
Doglao
PostPosted: Thu Nov 01, 2007 1:27 pm     Reply with quote
   i2c_start();
Have you tried to swap the acknowledge parameter in the two read commands?
I looked at the Microchip Application note AN845 for the similar MCP3221 chip and there they do first an ACK0 and then ACK1. So it becomes:
   i2c_start();
   msb   = i2c_read(0); //ACK 0
   lsb   = i2c_read(1); // ACK 1
rnielsen
PostPosted: Thu Nov 01, 2007 1:51 pm     Reply with quote
The terminology can be a bit confusing here. The command i2c_read(1), which is the default, tells the Master to send an ACK, negative pulse on the SDA line, to the Slave. An i2c_read(0) sends a NOACK. The proper communication sequence is:
i2c_start();
i2c_write(address);
msb = i2c_read(1);
lsb = i2c_read(0);
i2c_stop();
This would correspond with the I2C standard to send a NOACK on the last read(which tells the slave that the read sequence is over) and it is what the app note states to do.
The most likely problem is that the incorrect address is being sent. That's why I asked for the complete part number of the A/D so I could tell what address should be sent.
Ronald
PostPosted: Thu Nov 01, 2007 2:46 pm     Reply with quote
Try a more simple program:
#include <16F628A.H>
#fuses XT,NOWDT,PUT,NOBROWNOUT,NOLVP
#use i2c(master, scl=PIN_A2, sda=PIN_A3)
#include <flex_lcd.c>
#define MCP3021_READ_ADDR 0b10011011
int16 read_mcp3021(void)
int8 lsb;
int8 msb;
int16 retval;
i2c_start();
i2c_write(MCP3021_READ_ADDR);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
retval = make16(msb, lsb) >> 2;
return(retval);
int16 result;
lcd_init();
   result = read_mcp3021();
   printf(lcd_putc, "\f%lx    ", result);
Doglao
PostPosted: Thu Nov 01, 2007 4:06 pm     Reply with quote
Thanks for all!
it is working now!
I put a 11us delay before read the data, this delay is necessary to make a acquisition time Tacq(1.12usec) plus Conversion Time Tconv(8.96) and this work well, the values changing linearity. the other thing that I know now, is to join msb and lsb with make16() command.
very very very thanks!!
Doglao
