Bug in 18F4525 ?
Orcino
Bug in 18F4525 ?
PostPosted: Tue Nov 06, 2007 10:28 am     Reply with quote
Hi, i have a problem with the small prg for test, in 18F452 work right, but in 18F4525 not work right, see below
// #include <18F452.h>
#include <18F4525.h>
#FUSES HS
#FUSES NOPROTECT           //Code not protected from reading
#FUSES NOBROWNOUT               //Reset when brownout detected
#FUSES PUT                      //Power Up Timer
#use delay(clock = 20 Mhz)
struct SGPSCoord
    int buffer_latitude;
    int buffer_longetude;
    int distancia;
    int ponto;
    int status;
    int flag_lido;
struct SGPSCoord GPSCOORD[100];
//                                           Funções
void InverteElementos(struct SGPSCoord *pCoordenadas, int nE1, int nE2 );
void BubbleSort( int nQtdElementos, struct SGPSCoord *pCoordenadas );
void preenche_estrutura(void);
void mostra(void);
void calcula_distancias_ordena(void);
 int cont1;
 preenche_estrutura();
 BubbleSort(20,GPSCOORD);
 for(cont1=0;cont1 < 20 ; cont1++)
      printf("\nValor %u posicao %u\r",GPSCOORD[cont1].distancia, cont1 );
//                                           Ordenação
    int nBase, nCursor;
      for( nBase = 0; nBase < nQtdElementos - 1; ++nBase )
       for( nCursor = nBase + 1; nCursor < nQtdElementos; ++nCursor )
         if( pCoordenadas[ nBase ].distancia > pCoordenadas[nCursor ].distancia )
               InverteElementos( pCoordenadas, nBase, nCursor );
//                                                     SWAP
  struct SGPSCoord sTemp;
     memcpy( &sTemp, &pCoordenadas[ nE1 ], sizeof( sTemp ));
     memcpy( &pCoordenadas[ nE1 ], &pCoordenadas[ nE2 ], sizeof( sTemp ));
     memcpy( &pCoordenadas[ nE2 ], &sTemp, sizeof( sTemp ));
//                                                  Test
         GPSCOORD[0].distancia = 12;
         GPSCOORD[1].distancia = 33;
         GPSCOORD[2].distancia = 32;
         GPSCOORD[3].distancia = 45;
         GPSCOORD[4].distancia = 67;
         GPSCOORD[5].distancia = 34;
         GPSCOORD[6].distancia = 65;
         GPSCOORD[7].distancia = 73;
         GPSCOORD[8].distancia = 56;
         GPSCOORD[9].distancia = 19;
         GPSCOORD[10].distancia = 0;
         GPSCOORD[11].distancia = 1;
         GPSCOORD[12].distancia = 4;
         GPSCOORD[13].distancia = 8;
         GPSCOORD[14].distancia = 9;
         GPSCOORD[15].distancia = 3;
         GPSCOORD[16].distancia = 11;
         GPSCOORD[17].distancia = 13;
         GPSCOORD[18].distancia = 15;
         GPSCOORD[19].distancia = 100;
treitmey
PostPosted: Tue Nov 06, 2007 11:35 am     Reply with quote
With a few debug changes ((and using 3.249)) I'm getting
START
Valor 0 posicao 0
Valor 1 posicao 1
Valor 3 posicao 2
Valor 4 posicao 3
Valor 8 posicao 4
Valor 9 posicao 5
Valor 11 posicao 6
Valor 12 posicao 7
Valor 13 posicao 8
Valor 15 posicao 9
Valor 19 posicao 10
Valor 32 posicao 11
Valor 33 posicao 12
Valor 34 posicao 13
Valor 45 posicao 14
Valor 56 posicao 15
Valor 65 posicao 16
Valor 67 posicao 17
Valor 73 posicao 18
Valor 100 posicao 19
What are you expecting?
