Changing the baudrate
domdom
PostPosted: Mon Oct 22, 2007 7:39 pm     Reply with quote
Hi all,
I did some search in the forum, but i failed to find any example related to my project.
My PIC will receive a data from a GPS with 9600bps and transmit the data to PC with 4800bps.
How can I change the baudrate in between receive and transmit of the PIC with device?
Thanks!
PostPosted: Tue Oct 23, 2007 10:17 am     Reply with quote
For the hardware UART, use the setup_uart() function. It's in the manual.
For software UART, see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=31754
grasspuddle
PostPosted: Wed Oct 24, 2007 9:20 am     Reply with quote
It might be easier to use 2 #use commands.
Try:
#use RS232(baud=4800,parity=N,xmit=PIN_C6,bits=8,STREAM=OUT_UART)
#use RS232(baud=9600,parity=N,rcv=PIN_C7,bits=8,STREAM=IN_UART)
Of course, replace the 2 pins with your pins. I haven't tested hardware IO pins before, but it does seem to compile.
frequentguest
PostPosted: Wed Oct 24, 2007 11:17 am     Reply with quote
If you don't specify both hardware UART pins in the #use rs232 statement, then it will automatically create a soft UART.
To use the hardware on the PIC, you will have to use the set_uart_speed (baud, [stream, clock]) function to change the hardware UART baud rate.
You can specify two different #use rs232 statements with only one pin each (as grasspuddle suggested), but it won't take advantage of the PIC's hardware UART.
SherpaDoug
PostPosted: Wed Oct 24, 2007 1:46 pm     Reply with quote
To clarify: The hardware UART requires both its Xmit and Rec to run at the same baud rate.
frequentguest
PostPosted: Wed Oct 24, 2007 1:58 pm     Reply with quote
Thanks... It made more sense in my head.
grasspuddle
PostPosted: Thu Oct 25, 2007 12:58 pm     Reply with quote
what sherpa said ^^^
use rec for hardware, and try to use another pin for software xmit
receive is important for hardware, but you can usually get away with a software xmit
libor
PostPosted: Thu Oct 25, 2007 2:01 pm     Reply with quote
GPS sends its data (sentences) only once a second. I suppose you are doing some operation on these data (e.g. logging) and you are also sending them to the PC.
If you make it in a way that you are not receive and transmit at the same time (this is how you would do it anyway, isn't it ?), then you can use the hw usart for both operations switching the speed in between.
(the only caveat here is that the PIC will be deaf to any 9600 bps incoming data while it transmits at 4800, if you make the transmit in the timeframe the GPS is not talking anyway, it will result no drawback)
