Built-in Function, read_program_memory()
Matthias
PostPosted: Thu Oct 25, 2007 4:12 am     Reply with quote
I want to use the built-in function read_program_memory() with PIC16F690. I use it to read out the program memory for calculating CRC16.
In my program I want to calculate CRC16 after power on and after software reset. In case of power on, all is ok.
After a reset, this function doesn't read memory at the given adress but at last used adress.
May someone help me?
Best regards
Matthias
PostPosted: Thu Oct 25, 2007 12:29 pm     Reply with quote
The function interface looks like this:
read_program_memory(address, buffer, count);
Where do you get the address parameter for the read_program_memory
function ?
Is it a constant value ? Or do you read it from data eeprom ?
