Joined: 30 Aug 2007 Posts: 144 Location: South Africa
RC6 & RC7 normal I/O problem
Posted: Tue Oct 30, 2007 2:23 pm
I have been running into some trouble using rc6 and rc7 as normal I/O pins. I have set all the triss values as needed but i still am not able to use those pins as normal I/O pins. Is it possible as the data sheet says or do i need to do other adjustments as well?
It is for a 16F886 pic.
Posted: Tue Oct 30, 2007 3:02 pm
Make sure you don't specify those pins in a #use rs232() statement.
If you do, it will turn on the hardware UART, which uses those pins.
Gerhard
Posted: Tue Oct 30, 2007 3:41 pm
Could you please look at the code at the folowing website. I see that they have set the Xmit in the defines file but i cant see where it has been used so i am thinking of removing it. The pic is still the same 16f886 conected to a cc1000 but not through the rx and tx pins.
http://www.mohag.net/ccscc1000code
Posted: Tue Oct 30, 2007 4:02 pm
The code uses the serial port in a large number of places:
