RS-232 and PIC16F876: Buffer problem?
isabele_cda
PostPosted: Sun Oct 21, 2007 6:44 pm     Reply with quote
Hello!
I'm trying to developed a system using PIC16F876 and the RS-232 protocol. My main goal is to receive information from the ADC0, send it to the PC through the serial port, and receive data from the PC to set the PIC's PWM. I'm currently using the default I/O ports TX and RX from the PIC (ports 17 and 18) and MAX232 to implement the RS-232 protocol.
Everything seems to be going well, I receive and transmits data for some time, until the PIC suddenly stops responding. I don't know what is happening since my PIC code is extremely simple and I can't seem to find any hardware error. The only thing I can think of is the receiving buffers since I'm sending and receiving data constantly, so I would like to know more about that.
Any help would be welcomed. For a better analysis my code is presented bellow.
#if defined(__PCM__)
#include <16F876A.h>
#use delay(clock=10000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK)
#elif defined(__PCH__)
#include <18F452.h>
#include <stdlib.h>
void main ()
   int adc;
   int pwm1;
   int pwm2;
   char value = '\0';
   int valueI = 0;
   setup_ccp1 (CCP_PWM);
   setup_ccp2 (CCP_PWM);
   setup_port_a(ALL_ANALOG);
   setup_adc(adc_clock_internal);
   set_adc_channel( 0 );
   setup_timer_2(T2_DIV_BY_1, 255, 1);
      adc=read_adc();
      printf("%c",adc);
      delay_ms (250);
      if(kbhit())
         value = getc();
         valueI = (int)value;
      if (valueI <128)
         set_pwm2_duty(0);
         pwm1 = (valueI*2);
         set_pwm1_duty(pwm1);
         set_pwm1_duty(0);
         pwm2 = (valueI - 128);
         pwm2 = (pwm2 * 2);
         set_pwm2_duty(pwm2);
Thanks in advance for your time.
PostPosted: Sun Oct 21, 2007 8:02 pm     Reply with quote
The only thing I can think of is the receiving buffers.
adc=read_adc();
printf("%c",adc);
delay_ms (250);
if(kbhit())
value = getc();
The 250 ms delay will prevent you from reading the hardware UART's
receive buffer during that time. The UART only has a 2-byte receive fifo.
If you send more characters than that, it will get an overrun error and
lock up. You can tell the compiler to automatically clear the lockup
condition by adding the ERRORS directive, as shown in bold:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK, ERRORS)
This will cure the lockups, but you will still lose characters.
A better solution would be to add an interrupt-driven software receive fifo.
See the CCS example file, Ex_Sisr.c, for an example of how to do this.
It's in this directory:
c:\Program Files\Picc\Examples
isabele_cda
PostPosted: Sun Oct 21, 2007 8:47 pm     Reply with quote
The delay was used at first as a kind of debug (print the result on Windows hyperterminal in a frequency we could see - we were using 1s). I guess we forgot to ajust it later. Thanks for pointing it out! Smile
I'll try this modification later this week and let you know the results.
Thank you very much!
