USB Descriptors for Composite Devices
Tre
PostPosted: Tue Mar 28, 2006 10:06 pm     Reply with quote
I am trying to create a USB descriptor for a composite device. (www.zero-soft.com/HW/USB_NES when the hosting is actually working)
However, I am having a slight problem with the strings. I have defined all of my strings in the descriptor and I use the index of the strings I want to display in the interface descriptor for each of the two endpoints. During enumeration the correct names show up in the yellow balloons that windows has. However, when I go in and look at the devices in the control panel they both have the name of interface 1 (in this case "Controller A").
Anyone see anything that I am missing? Thanks!
PS: Sorry I can't figure out how to attach this, I guess i'll just have to paste it :<
#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
#include <usb.h>
   ///  HID Report.  Tells HID driver how to handle and deal with
   ///  received data.  HID Reports can be extremely complex,
   ///  see HID specifcation for help on writing your own.
   ///  First it defines a block for the first interface for a mouse
   ///  protocol.  Second it defines a block for the second interface
   ///  for a keyboard protocol.
   const char USB_CLASS_SPECIFIC_DESC[] = {
   // HID Descriptor for Interface 0 (Controller A)
   0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)        // 0,1
    0x09, 0x04,                    // USAGE (Joystick)               // 2,3
    0xa1, 0x01,                    // COLLECTION (Application)         // 4,5
    0x09, 0x01,                    //   USAGE (Pointer)               // 6,7
    0xa1, 0x00,                    //   COLLECTION (Physical)         // 8,9
    0x09, 0x30,                    //     USAGE (X)                  // 10,11
    0x09, 0x31,                    //     USAGE (Y)                  // 12, 13
    0x15, 0x81,                    //     LOGICAL_MINIMUM (-127)      // 14, 15
    0x25, 0x7f,                    //     LOGICAL_MAXIMUM (127)         // 16, 17
    0x75, 0x08,                    //     REPORT_SIZE (8)            // 18, 19
    0x95, 0x02,                    //     REPORT_COUNT (2)            // 20, 21
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)         // 22, 23
    0x05, 0x09,                    //     USAGE_PAGE (Button)         // 24, 25
    0x19, 0x01,                    //     USAGE_MINIMUM (Button 1)      // 26, 27
    0x29, 0x08,                    //     USAGE_MAXIMUM (Button 8)      // 28, 29
    0x15, 0x00,                    //     LOGICAL_MINIMUM (0)         // 30, 31
    0x25, 0x01,                    //     LOGICAL_MAXIMUM (1)         // 32, 33
    0x75, 0x01,                    //     REPORT_SIZE (1)            // 34, 35
    0x95, 0x08,                    //     REPORT_COUNT (8)            // 36, 37
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)         // 38, 39
    0xc0,                          //   END_COLLECTION               // 40
    0xc0                           // END_COLLECTION               // 41
   // HID Descriptor for Interface 1 (Controller B)
    0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)      // 42, 43
    0x09, 0x04,                    // USAGE (Joystick)               // 44, 45
    0xa1, 0x01,                    // COLLECTION (Application)         // 46, 47
    0x09, 0x01,                    //   USAGE (Pointer)               // 48, 49
    0xa1, 0x00,                    //   COLLECTION (Physical)         // 50, 51
    0x09, 0x30,                    //     USAGE (X)                  // 52, 53
    0x09, 0x31,                    //     USAGE (Y)                  // 54, 55
    0x15, 0x81,                    //     LOGICAL_MINIMUM (-127)      // 56, 57
    0x25, 0x7f,                    //     LOGICAL_MAXIMUM (127)         // 58, 59
    0x75, 0x08,                    //     REPORT_SIZE (8)            // 60, 61
    0x95, 0x02,                    //     REPORT_COUNT (2)            // 62, 63
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)         // 64, 65
    0x05, 0x09,                    //     USAGE_PAGE (Button)         // 66, 67
    0x19, 0x01,                    //     USAGE_MINIMUM (Button 1)      // 68, 69
    0x29, 0x08,                    //     USAGE_MAXIMUM (Button 8)      // 70, 71
    0x15, 0x00,                    //     LOGICAL_MINIMUM (0)         // 72, 73
    0x25, 0x01,                    //     LOGICAL_MAXIMUM (1)         // 74, 75
    0x75, 0x01,                    //     REPORT_SIZE (1)            // 76, 77
    0x95, 0x08,                    //     REPORT_COUNT (8)            // 78, 79
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)         // 80, 81
    0xc0,                          //   END_COLLECTION               // 82
    0xc0                           // END_COLLECTION               // 83
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][2] =
   //config 1
      //interface 0
         0,
      //interface 1
         42
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][2] =
   //config 1
      //interface 0
         42,
      //interface 1
         42
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      59 //config+interface+class+endpoint
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size          ==0
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)     ==1
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==2,3
         2, //number of interfaces this device supports       ==4
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==5
         0x00, //index of string descriptor for this configuration      ==6
         0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==7
         0x32, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)   //8
   //interface descriptor 1 (NES Controller A)
         USB_DESC_INTERFACE_LEN, //length of descriptor      =9
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =10
         0x00, //number defining this interface (IF we had more than one interface)    ==11
         0x00, //alternate setting     ==12
         1, //number of endpoints for this interface  //13
         0x03, //class code, 03 = HID     ==14
         0x01, //subclass code //boot     ==15
         0x02, //protocol code            ==16
         0x02, //index of string descriptor for interface      ==17
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==18
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==19
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==20,21
         0x00, //localized country code (0 = none)       ==22
         0x01, //number of hid class descrptors that follow (1)      ==23
         0x22, //report descriptor type (0x22 == HID)                ==24
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==25,26
   //endpoint descriptor 1
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==27
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==28
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==29
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)         ==30
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==31,32
         10,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)     ==33
   //interface descriptor 2 (NES Controller B)
         USB_DESC_INTERFACE_LEN, //length of descriptor      =34
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =35
         0x01, //number defining this interface (IF we had more than one interface)    ==36
         0x00, //alternate setting     ==37
         1, //number of endpoints for this interface  //38
         0x03, //class code, 03 = HID     ==39
         0x01, //subclass code //boot     ==40
         0x02, //protocol code (keyboard)      ==41
         0x03, //index of string descriptor for interface      ==42
   //class descriptor 2
         USB_DESC_CLASS_LEN, //length of descriptor    ==43
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==44
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==45,46
         0x00, //localized country code (0 = none)       ==47
         0x01, //number of hid class descrptors that follow (1)      ==48
         0x22, //report descriptor type (0x22 == HID)                ==49
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][1], 0x00, //length of report descriptor            ==50,51
   //endpoint descriptor 2 IN
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==52
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==53
         0x82, //endpoint number and direction (0x81 = EP1 IN)       ==54
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)         ==55
         USB_EP2_TX_SIZE,0x00, //maximum packet size supported                  ==56,57
         10  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)     ==58
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   2
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   2
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={2};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][2][1]=
   //config 1
      //interface 0
         //class 1
         18,
      //interface 1
         //class 1
         43
   //****** END CONFIG DESCRIPTOR LOOKUP TABLES ********
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
///   start device descriptors
   const char USB_DEVICE_DESC[] = {
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
         0x00, //class code ==5
         0x00, //subclass code ==6
         0x00, //protocol code ==7
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
         0x61,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
         0x4C,0x00, //product id   ==11,12  //don't use ffff says usb-by-example guy.  oops
         0x00,0x01, //device release number  ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==15
         0x01, //index of string descriptor of the product  ==16
         0x00, //index of string descriptor of serial number  ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==18
   #if (sizeof(USB_DEVICE_DESC) != USB_DESC_DEVICE_LEN)
      #error USB_DESC_DEVICE_LEN not defined correctly
///   start string descriptors
///   String 0 is a special language string, and must be defined.  People in U.S.A. can leave this alone.
//the offset of the starting location of each string.  offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
const char USB_STRING_DESC_OFFSET[]={0,4,24,78};
//number of strings you have, including string 0.
#define USB_STRING_DESC_COUNT sizeof(USB_STRING_DESC_OFFSET)
char const USB_STRING_DESC[]={
   //string 0
         4, //length of string index
         USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
         0x09,0x04,   //Microsoft Defined for US-English
   //string 1
         20, //length of string index
         'Z',0,
         'e',0,
         'r',0,
         'o',0,
         '-',0,
         'S',0,
         'o',0,
         'f',0,
         't',0,
   //string 2
         54, //length of string index
         'Z',0,
         'e',0,
         'r',0,
         'o',0,
         '-',0,
         'S',0,
         'o',0,
         'f',0,
         't',0,
         ' ',0,
         'N',0,
         'E',0,
         'S',0,
         ' ',0,
         'C',0,
         'o',0,
         'n',0,
         't',0,
         'r',0,
         'o',0,
         'l',0,
         'l',0,
         'e',0,
         'r',0,
         ' ',0,
         'A',0,
   //string 3
         'Z',0,
         'e',0,
         'r',0,
         'o',0,
         '-',0,
         'S',0,
         'o',0,
         'f',0,
         't',0,
         ' ',0,
         'N',0,
         'E',0,
         'S',0,
         ' ',0,
         'C',0,
         'o',0,
         'n',0,
         't',0,
         'r',0,
         'o',0,
         'l',0,
         'l',0,
         'e',0,
         'r',0,
         ' ',0,
         'B',0
Tre
Class Descriptors
PostPosted: Tue Mar 28, 2006 11:24 pm     Reply with quote
After looking at it again (and again, and again...) I think that I may have found an error in the mouse/keyboard code.
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][USB_NUM_HID_INTERFACES][2]=
   //config 1
      //interface 0
         //class 1
         18,
   //interface 1
         //class 1
         44
This doesn't seem to be correct if you have more than one class for an interface which the keyboard/mouse and my code do....
Anyone else care to comment on this?
