PIT! Guest
Help with interruptions please. |
Posted: Thu Oct 04, 2007 2:55 pm |
I guess I posted before, but I can´t find the post sorry! =/
First thing, I use MPLAB 7.61 with CCS 3.184.
I´m using this 2 programs:
Master:
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use rs232 (baud=9600, xmit=pin_c6, rcv=pin_c7, parity=n, bits=8)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
int c;
glcd_gotoxy(1,1,1);
glcd_putc("Pic:");
// Write the letter 'B' to the slave board.
i2c_start();
i2c_write(0x70);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
i2c_start();
i2c_write(0x70);
i2c_write(0x01);
i2c_write('C');
i2c_stop();
i2c_start();
i2c_write(0x70);
i2c_write(0x02);
i2c_write('D');
i2c_stop();
// Read from the slave board and display the data.
i2c_start();
i2c_write(0x70);
i2c_write(0x00);
i2c_start();
i2c_write(0x71);
dado_com[0] = i2c_read(0);
i2c_stop();
posx=1;
posy=2;
for (i=0; i<8; i++)
if (bit_test(dado_com[0],7-i)==1)
glcd_gotoxy(posx,posy,1);
glcd_putc("1");
else if (bit_test(dado_com[0],7-i)==0)
glcd_putc("0");
posx++;
posx=1;
posy=3;
i2c_start();
i2c_write(0x70);
i2c_write(0x01);
i2c_start();
i2c_write(0x71);
dado_com[1] = i2c_read(0);
i2c_stop();
for (i=0; i<8; i++)
if (bit_test(dado_com[1],7-i)==1)
glcd_putc("1");
else if (bit_test(dado_com[1],7-i)==0)
glcd_putc("0");
posx++;
posx=1;
posy=4;
i2c_start();
i2c_write(0x70);
i2c_write(0x02);
i2c_start();
i2c_write(0x71);
dado_com[2] = i2c_read(0);
i2c_stop();
for (i=0; i<8; i++)
if (bit_test(dado_com[2],7-i)==1)
glcd_putc("1");
else if (bit_test(dado_com[2],7-i)==0)
glcd_putc("0");
posx++;
glcd_gotoxy(1,6,1);
glcd_putc("Memoria:");
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1);
i2c_stop();
posx=1;
posy=7;
for (i=0; i<8; i++)
glcd_putc("1");
glcd_putc("0");
posx++;
posx=1;
posy=8;
i2c_start();
i2c_write(0xA0);
i2c_write(0x01);
i2c_start();
i2c_write(0xA1);
i2c_stop();
for (i=0; i<8; i++)
glcd_putc("1");
glcd_putc("0");
posx++;
posx=1;
posy=9;
i2c_start();
i2c_write(0xA0);
i2c_write(0x02);
i2c_start();
i2c_write(0xA1);
i2c_stop();
for (i=0; i<8; i++)
glcd_putc("1");
glcd_putc("0");
posx++;
Slave:
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x70)
typedef enum {NOTHING, CONTROL_READ,
ADDRESS_READ, READ_COMMAND_READ} I2C_STATE;
I2C_STATE fState;
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt ()
BYTE incoming;
if (i2c_poll() == FALSE) {
if (fState == ADDRESS_READ) { //i2c_poll() returns false on the
i2c_write (buffer[address]);//interupt receiving the second
fState = NOTHING; //command byte for random read operation
else {
output_b(0x55);
incoming = i2c_read();
if (fState == NOTHING){
fState = CONTROL_READ;
else if (fState == CONTROL_READ) {
address = incoming;
fState = ADDRESS_READ;
else if (fState == ADDRESS_READ) {
buffer[address] = incoming;
fState = NOTHING;
void main ()
int i;
fState = NOTHING;
address = 0x00;
for (i=0;i<0x10;i++)
buffer[i] = 0x00;
enable_interrupts(INT_SSP);
output_b(0xAA);
while (TRUE) {
My problem is that every time I use interruptions, it reloads all the main!
Exemple:
With the output_b(0xAA) my led´s stay green, with the output_b(0x55) they stay red.
So when I get a interrupt, it stays like 1 second red, then goes back to green. It should never go back to green.
I have a 24c08 and the pic on the i2c line. The read memory part works fine, but the pic part gets only 11111111 ( because of the pull-up resistors ).
I hope you understand it!
Thanks |
Posted: Thu Oct 04, 2007 3:06 pm |
There is a problem in your thinking.
Don't use I2C_POLL for this. It says a byte has been received. You need to load the byte to be read back, for your 'read' operation on the master,_when the address has been received, with the low bit set_. I2C_POLL, will still be true at this point. This is why there is I2C_ISR_STATE, which allows you to detect the read/write bit.
PIT! Guest
Posted: Fri Oct 05, 2007 5:04 am |
But that is the ex_slave.c
Just added the output_b lines, to see where my error was!
And my version of ccs does not have i2c_isr_state.
Here is the notice from the CCS versions page of when it was added:
3.231 New function added: I2C_ISR_STATE()
Mine is CCS 3.184. =/
Thanks |
Posted: Fri Oct 05, 2007 5:13 am |
Do a search on the forum. There has been a replacement I2C_ISR_STATE function published in the past for use in the older compilers. I'm afraid I don't think CCS, actually tried what they posted, and when they did, they realised that they needed to check the R/W bit, and added I2C_ISR_STATE....
PIT! Guest
Posted: Fri Oct 05, 2007 5:16 am |
Yeh i found it, thanks.
But i don´t think the problem is the actual function, is the fact that is reload the main.
Because every interruption i make, it reloads the constants of the initialize program. So it is impossible to work with any program.
Thanks. |
Posted: Fri Oct 05, 2007 6:57 am |
The only thing wrong with the master main, is that it'll drop off the end (need something to stop this...). However this won't cause a restart (since WDT is disabled).
There are some 'nasties' in the slave (for instance, what happens if the master accidentally sends bore than 0x10 bytes?....
