12f629 reset problem
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Thu Oct 04, 2007 10:53 pm     Reply with quote
Dear sir,
here i am using 12f629, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534
In my circuit i have connected switch to pin no. 4 and LED at pin no. 5
And using internal MCLR. I have to make LED ON whenever switch is ON
i.e. closed & i/p at pin no. 4 is logic zero.
And OFF when switch is OFF i.e. open & i/p at pin no. 4 is logic one.
for this purpose i used the statements like this,
if(INPUT(PIN_A3)== 0)
LED ON; //switch closed i.e s/w ON
LED OFF; // switch open i.e. s/w OFF
BUT for this i am not using any pull up for switch & making this pin as out put pin.
Bcz i want check only logic level of pin no.4
This is working OK,
But sometimes the microcontroller not reseting.forcefully I have to connect pin no.4
to GND.
it is necessary to make pin no.4 as input to check logic level to avod reseting problem
Thank You,
With Best Regards,
Deepak.
PostPosted: Fri Oct 05, 2007 12:17 am     Reply with quote
Post the test program.
deepakomanna
PostPosted: Fri Oct 05, 2007 2:30 am     Reply with quote
Here is my test programe,
#if defined(__PCM__)
#include<12F629.h>
#fuses INTRC_IO,NOWDT,PUT,NOMCLR,PROTECT,NOCPD,BROWNOUT
//Internal RC Osc, no CLKOUT,No Watch Dog Timer,Power Up Time ON,Internal MCLR,Code Protect ON,No EE protection,Brownout detect ON,
#use delay(clock = 4000000)   // INTERNAL 4 MHz FREQ.
PORT_A_PULLUPS(FALSE);
SET_TRIS_A(0x00);
SETUP_COMPARATOR(NC_NC_NC_NC);      // Make comparator off
      if(INPUT(PIN_A3) == 0)
         OUTPUT_HIGH(PIN_A2);
         OUTPUT_LOW(PIN_A2);
Thank You,
With Best Regards,
Deepak.
adrian
PostPosted: Fri Oct 05, 2007 5:47 am     Reply with quote
OK there are a number of things wrong here.
In my circuit i have connected switch to pin no. 4 and LED at pin no. 5 And using internal MCLR.
and
But sometimes the microcontroller not reseting.forcefully I have to connect pin no.4 to GND.
If you use the internal MCLR, the only way to reset the device is to turn the power off and on again.
Also
You cant - MCLR pin is an input only.
You need a pull up resistor, otherwise the pin is floating.
I see that you have dabbled with
If you are hoping to use the internal pull up resistor for the switch - you can't because there isn't one.
Although not stated, you do have resistors on the LED I hope?
You will also have to look at debouncing of you switch.
