debugging problem
deelip_prusty
debugging problem
PostPosted: Thu Oct 04, 2007 8:15 am     Reply with quote
Hi
All
I have MPLAB IDE 7.52 , CCS Compiler , LCM Hybrid Demo board and MPlab LCD2 debugger.
I compiled a sample example which is given in PICC ,got Build Succeded result
How can i debug this using the devices which i have?
Is it necessary to connect the Mplab Lcd2 debugger with the Demo board or only with Mplab lcd2 debugger can do it.?
Kindly give some suggestions ,how can i debug it?
PostPosted: Thu Oct 04, 2007 11:30 am     Reply with quote
Please don't start a new topic every day, and ask the same question
that you asked in the previous topic.
How to setup MPLAB to use the CCS compiler.
http://www.ccsinfo.com/faq.php?page=ccs_mplab6
How to use ICD2 to step through a simple program and watch a
variable in the Watch Window:
http://www.ccsinfo.com/forum/viewtopic.php?t=23151&start=9
