Wrong output freq timer2, Why?
The Puma
PostPosted: Thu Oct 04, 2007 6:47 am     Reply with quote
Strange result for this example
This give a freq of 19.5Khz (scope)
but this should be 39Khz
Do i something wrong???
#include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
//   The cycle time will be (1/clock)*4*t2div*(period+1)
//   In this program clock=20000000 and period=127
//   (1/20000000)*4*1*128=25.6us or 39.0khz
#int_TIMER2
void TIMER2_isr() {
   output_toggle(PIN_C1);
   setup_timer_2(T2_DIV_BY_1,127,1);
   while(TRUE) {
Ken Johnson
PostPosted: Thu Oct 04, 2007 7:15 am     Reply with quote
The square-wave frequency (on the scope) is one-half the isr frequency.
Ken
rnielsen
PostPosted: Thu Oct 04, 2007 8:22 am     Reply with quote
Your ISR is being entered at a frequency of 39KHZ. You are simply toggling the output which, in effect, is acting as a divide-by-two. If you want to get 39KHZ out of the output then your ISR will need to toggle the output both UP and DOWN to get a 1:1 ratio out.
Ronald
_______________________
Only open up a can of worms if you're going fishing.
