Hi all, i have a small problem with delay_ms() and delay_us() functions. I`m trying to control some servomotors with this functions and i need something like "delay_ms(x)" for a smoother controll in which "x" is a variable that increments and decrements.BUT the problem is that function delay_ms() doesn`t support a variable like that(simply don`t work). I tried to make my own delay functions :
void delay_u(long int u){
long int i;
for(i=0;i<u;i++){
delay_cycles(5); // 20Mhz = 200ns *5 =1us
void delay_m(long int m){
long int j;
for(j=0;j<m;j++){
delay_u(1000);
this doesn`t work either.
I`m using a 20Mhz crystal and CCS versions 3.203 or 3.22
Can somebody help me please???
Many thanx,
Vodka
Posted: Wed Oct 03, 2007 7:58 am
Here are two functions for a long delay with a variable parameter (16-bit).
You only need these functions if you have vs. 2.xxx or 3.xxx of the
compiler. In version 4, this feature is included in the delay_us() and
delay_ms() functions.
Vodka
Posted: Wed Oct 03, 2007 11:12 am
Yes indeed it works, very silly of me .
Thanks again PCM programmer very much
