About floating point
PostPosted: Tue Oct 02, 2007 4:39 pm     Reply with quote
Thanks for your reply. Is it possible to send it to any output port?
And you said about scaling. Actually what did you mean by scaling?
Thanks again
Nilim
PostPosted: Tue Oct 02, 2007 4:44 pm     Reply with quote
You shouldn't start a new topic just to thank someone.
Add the "thank you" to the existing topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=32271
Also, if you have further questions on the same topic, such
as 'scaling', then ask the questions by adding a post to the same
original topic.
When you add a new post, the topic will go to the top of the forum.
Everyone will see it.
