Eeprom_programmer
| Eeprom problems |
Posted: Tue Oct 02, 2007 3:23 am |
Hey,
I really need help, i have been struggeling with programming a eeprom to function as follow. It must only log data when the motion sensor is high. And it must read the data when there is 10 values logged.
But it doesn't want to work. Please help me, i posted the code below
#include "16f883.h"
#use DELAY(clock=4000000)
#fuses HS,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT,NOWRT
#use rs232(baud=9600, xmit=PIN_C6, rcv= PIN_C7)
#use i2c(master,sda=PIN_C4, scl = PIN_C3)
#define MAX_TICKS 3
#define address 0x08
#bit RELAY = PORTC.2
//Components
#define EE_BLOCK 8 //5 was vir ekstra coils
#define COIL_1 PIN_C2
#case
// GLOBAL VARIABLES
int8 PIR = 0;
int8 POT = 0;
int8 LDR = 0;
int8 SWITCH_TIME;
int8 RecordNr = 0; // Moved the variable declarations out of the loop.
unsigned int16 recordNumber = 0;
unsigned int16 timeout =0;
// Structures
struct time
unsigned int ms; // Milliseconds
unsigned char ss ; // Seconds
unsigned char mm; // Minutes
unsigned char hh; // Hours
unsigned char day ; //day
unsigned char month; //Months
// Data structure for logging and modbus functions
typedef struct
int8 PIR_mod, // Sensor motion detection
POT_mod, // Sensitivity adjustments
LDR_mod, // Light intensity
temp_mod, // temprature value
coil_mod[3], // relay status
minute,
hour,
day,
month;
}ilINFO;// Intelli light data structure
ilINFO intelliINFO; // Stores info to be logged to EEPROM
struct time now = {0};
// Stel die A na D op
void setupADC ()
ADCON1 = 0x80; // moet in setup kom
ADCON0 = 0x00;
void setChannel ( unsigned char Channel )
unsigned char temp;
Channel = Channel & 0x0F;
Channel = Channel << 2;
ADCON0 = 0x03 | Channel;
unsigned int16 readADC ()
unsigned int16 Value;
ADCON0 = ADCON0 | 0x01; // turn on ADC
delay_ms(5);
ADCON0 = ADCON0 | 0x02; //start conversion stel 2de bus
while ( ADCON0 & 0x02 );
Value = ADRESH;
Value = ( Value << 8 ) | ADRESL;
return Value;
// LEES PIR
unsigned int8 readSensor()
unsigned int8 adcValue;
setChannel(0);
delay_ms(15);
adcValue = readADC(); // get ADC value from the sensor;
return adcValue;
// skryf na eeprom
// Writes to the slave board from the master.
void write_ext_eeprom(int16 ADDRESS, unsigned char data)
int8 status;
i2c_start();
i2c_write(0xAE);
i2c_write((int8)(ADDRESS>>8));
i2c_write((int8)ADDRESS);
i2c_write(data);
i2c_stop();
//delay_ms(5); delay is boarderline to the maximum waiting period - delay only if...do
do
i2c_start();
status=i2c_write(0xAE);
} while (status != 0);
// LEES
// Read from the slave board and display the data.
unsigned char read_ext_eeprom( int16 ADDRESS )
unsigned char data_read;
i2c_start();
i2c_write(0xAE);
i2c_write( (int8)(ADDRESS>>8));
i2c_write( (int8)ADDRESS);
i2c_start();
i2c_write(0xAF);
data_read = i2c_read(0);
i2c_stop();
delay_ms(5);
return data_read;
// This function will read a single log from the EEPROM and store it in a intelli light structure
void readEE(unsigned int16 ee_address , ilINFO *currentEntry)
// Move to correct block
ee_address = ee_address * EE_BLOCK ;
// Read EEPROM
currentEntry->PIR_mod = read_ext_eeprom(ee_address); // Day
printf(read_ext_eeprom(ee_address));
currentEntry->LDR_mod = read_ext_eeprom(ee_address+1);
printf(read_ext_eeprom(ee_address+1));
currentEntry->temp_mod = read_ext_eeprom(ee_address+2);
printf(read_ext_eeprom(ee_address+2));
currentEntry->coil_mod[0] = read_ext_eeprom(ee_address+3);
printf(read_ext_eeprom(ee_address+3));
currentEntry->minute = read_ext_eeprom(ee_address+4); //Stuur minute
printf(read_ext_eeprom(ee_address+4));
currentEntry->hour = read_ext_eeprom(ee_address+5); //Stuur ure
printf(read_ext_eeprom(ee_address+5));
currentEntry->day = read_ext_eeprom(ee_address+6); //Stuur dae
printf(read_ext_eeprom(ee_address+6));
currentEntry->month = read_ext_eeprom(ee_address+7); //Stuur maande
printf(read_ext_eeprom(ee_address+7));
// This function will log a single intelli light structure to EEPROM
void logtoEE(unsigned int16 ee_address, ilINFO *currentEntry)
ee_address = ee_address * EE_BLOCK;
// Write EEPROM
write_ext_eeprom(ee_address, currentEntry->PIR_mod); // Day
write_ext_eeprom(ee_address+1, currentEntry->LDR_mod); // Hour
write_ext_eeprom(ee_address+2, currentEntry->temp_mod); // Temprature(High byte) >> 8
write_ext_eeprom(ee_address+3, currentEntry->coil_mod[0]);
write_ext_eeprom(ee_address+4, currentEntry->minute);
write_ext_eeprom(ee_address+5, currentEntry->hour);
write_ext_eeprom(ee_address+6, currentEntry->day);
write_ext_eeprom(ee_address+7, currentEntry->month);
// Hier binne moet dit log as switch time verander
void light_on(int8 motionsensor)
if(motionsensor > 0)
output_high(PIN_C2);
intelliINFO.coil_mod[0] = 1;
++RecordNr; //Record number increment to save continiously
logtoEE(RecordNr, &intelliINFO); // A '&' indicates the compiler we want to pass the address of the struct
if(motionsensor == 0)
output_low(PIN_C2);
intelliINFO.coil_mod[0] = 0;
void readReference( unsigned int16 recordNUMBER )
ilINFO currentEntry;
readEE (recordNUMBER, ¤tEntry);
void setup()
set_tris_a(0x27); // Port A Direction
// RA0 : Sensor Input (1)
// RA1 : Sensitivity Input (1)
// RA2 : Sensitivity (1)
// RA3 : Not used (0)
// RA4 : Not used (0)
// RA5 : LDR (1)
set_tris_b(0x00); // Port B Direction
// RB0 : Not used (0)
// RB1 : RS-485 Direction Output (0)
// RB2 : LED1 Output (0)
// RB3 : LED2 Output (0)
// RB4 : LED3 Output (0)
// RB5 : RUN LED Output (0)
// RB6 : Not used (0)
// RB7 : Not used (0)
set_tris_c(0x80); // Port C Direction
// ADC Setup
setup_adc_ports( AN0_AN1_AN2_AN3_AN4 ); //sets port A to analogue
setup_adc( ADC_CLOCK_INTERNAL ); //enables the a/d module
setupADC();
setup_timer_2(T2_DIV_BY_4,155,2);
// Main Program!!!!
// Main Program
setup();
SWITCH_TIME = 5;
// Main Loop
PIR = readSensor(); //Lees die bewegings sensor
light_on(PIR);
intelliINFO.PIR_mod = PIR; // PIR sensor
intelliINFO.POT_mod = 2;
intelliINFO.LDR_mod = 3;
intelliINFO.temp_mod = 4;
intelliINFO.coil_mod[0] = RELAY;
if( RecordNr == 10)
readReference(1);
// TIMEOUT!!!!!!
#INT_TIMER2
void isr_TIMER2() //interrupt routine when overflow occurs in TIMER2. ====> VIR TIMEOUT
static unsigned char ticks = 0;
if(++ticks == 3) // 1 millisecond
// Software Clock
if(++now.ms == 1000) // One second elapsed
now.ms = 0;
if(++now.ss == 60) // One minute elapsed
now.ss = 0;
if(++now.mm == 60) // One hour elapsed
now.mm = 0;
if(++now.hh == 24) // One day elapsed
now.hh = 0;
if((++now.day == 31 && (now.month==4 || now.month==6 || now.month==9 || now.month==11 ))
|| (now.day == 32)
) {now.month++; now.day = 0;}
ticks = 0; // Reset ticks
intelliINFO.minute = now.mm;
intelliINFO.hour = now.hh;
intelliINFO.month = now.month;
intelliINFO.day = now.day;
