PIC16f877 & LCD problem
Vodka
PostPosted: Sun Sep 30, 2007 6:56 am     Reply with quote
Hi all, i`m trying to display something on my lcd but i can`t succeed.
I use a pic16f877 and a lcd(AC202A).
The pinout is:
B0 - unused
B1 - unused
B2 - enable
B3 - rs
B4 - data
B5 - data
B6 - data
B7 - data
rw - GND
so i use a 4 wire data for signalling.I modified the lcd.c file from root as follows(http://www.edaboard.com/ftopic64934.html):
________________________________________________
// Un-comment the following define to use port B
#define use_portb_lcd TRUE
struct lcd_pin_map {
BOOLEAN unused1; // For RB0
BOOLEAN unused2; // For RB1
BOOLEAN enable; // For RB2
BOOLEAN rs; // For RB3
int data : 4; // For RB4-RB7
} lcd;
comment any line contain 'rw.lcd'
The main code is:
#include <16F877.h>
#fuses XT // Oscillator mode
#fuses NOLVP, NOWDT // No Low Voltage Program, No Watchdog timer
#fuses NOPROTECT // Code no protection
#use delay(clock=20000000)
#include <lcd.c>
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
lcd_gotoxy(1,1);
lcd_putc("Hello");
The CCS compiler is version 3.249
I can`t see anything on my lcd!!!
Please help me,
Regards Vodka
PostPosted: Sun Sep 30, 2007 7:22 am     Reply with quote
You have 'XT' selected as the oscillator mode, but 20Mhz shown as the frequency in the delay statement. These two things are incompatible...
Are you sure you have the _right_ data lines selected. Note that in 4bit mode, it is the _high_ four data lines that are used. Double check your wiring.
Check/correct these.
What have you got on the Vlcd line for the display?.
Vodka
PostPosted: Sun Sep 30, 2007 8:19 am     Reply with quote
The wiring is all correct and about "What have you got on the Vlcd line for the display?. " i don`t understant what that means.
PostPosted: Sun Sep 30, 2007 6:55 pm     Reply with quote
Here's the data sheet for your LCD. This is a 20x2 LCD.
http://www.ampire.com.tw/Spec-AC/AC-202A.pdf
You're trying to use the LCD with the connections similar
to the schematic shown on this page, except that you
are using PortB instead of PortD and PortE. You are not
using the R/W pin. It's connected to Ground, as shown
in this schematic. Also, you must have a contrast trimpot
connected as shown in this schematic. You can use a 10K
trimpot. Set the initial contrast voltage to 0.5 volts.
http://www.rentron.com/PICX1.htm
I suggest that you don't try to modify the CCS driver.
It's easier to use the Flex driver. See this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Here are the #define statements that you must have at
the start of the Flex driver:
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_B2
#define LCD_RS    PIN_B3
#define LCD_RW    PIN_B1    // Not actually connected
// *** Comment out the following line ***
// #define USE_LCD_RW   1
ELCouz
PostPosted: Sun Sep 30, 2007 8:26 pm     Reply with quote
also if the lcd is giving you trouble to display something try:
lcd_gotoxy(1,1);
lcd_putc("Hello");
this give time to the lcd unit to boot before initialising & sending a command to the display.
Source: --> HERE
Vodka
PostPosted: Mon Oct 01, 2007 4:30 am     Reply with quote
Unfortunately i have tried the Flex driver and the delay_ms(100); before lcd_init() but i have no luck. If i use the flex driver i can`t see anything on my lcd and if i use the lcd.c file from root and modified as i shown i can see just the first black line appear.
Any new suggestions please ????
PostPosted: Mon Oct 01, 2007 11:08 am     Reply with quote
I can see just the first black line appear.
Here are some posts the problem of "black squares" on the first line
of your LCD.
http://www.ccsinfo.com/forum/viewtopic.php?t=29819
http://www.ccsinfo.com/forum/viewtopic.php?t=30993
http://www.ccsinfo.com/forum/viewtopic.php?t=28405
http://www.ccsinfo.com/forum/viewtopic.php?t=22713
http://www.ccsinfo.com/forum/viewtopic.php?t=23748
Fixing problems when using the Flex driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=27246
Read all those threads and you'll probably find the answer.
