Eeprom problems
Eeprom_programmer
Eeprom problems
PostPosted: Tue Oct 02, 2007 3:23 am     Reply with quote
Hey,
I really need help, i have been struggeling with programming a eeprom to function as follow. It must only log data when the motion sensor is high. And it must read the data when there is 10 values logged.
But it doesn't want to work. Please help me, i posted the code below
#include "16f883.h"
#use DELAY(clock=4000000)
#fuses HS,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT,NOWRT
#use rs232(baud=9600, xmit=PIN_C6, rcv= PIN_C7)
#use i2c(master,sda=PIN_C4, scl = PIN_C3)
#define MAX_TICKS 3
#define address 0x08
#bit RELAY = PORTC.2
//Components
#define EE_BLOCK   8  //5 was vir ekstra coils
#define COIL_1  PIN_C2
#case
// GLOBAL VARIABLES
int8 PIR = 0;
int8 POT = 0;
int8 LDR = 0;
int8 SWITCH_TIME;
int8 RecordNr = 0;  // Moved the variable declarations out of the loop.
unsigned int16 recordNumber = 0;
unsigned int16 timeout =0;
// Structures
struct time
   unsigned int ms;                  // Milliseconds
   unsigned char ss ;                  // Seconds
   unsigned char mm;                  // Minutes
   unsigned char hh;                  // Hours
   unsigned char day ;              //day
   unsigned char month;           //Months
//                         Data structure for logging and modbus functions
typedef struct
    int8         PIR_mod,          // Sensor motion detection
              POT_mod,          // Sensitivity adjustments
              LDR_mod,          // Light intensity
                temp_mod,        // temprature value
              coil_mod[3],        // relay status
              minute,
              hour,
              day,
              month;
}ilINFO;// Intelli light data structure
ilINFO intelliINFO; // Stores info to be logged to EEPROM
struct time now = {0};
//                              Stel die A na D op
void setupADC ()
ADCON1 = 0x80; // moet in setup kom
ADCON0 = 0x00;
void setChannel ( unsigned char Channel )
 unsigned char temp;
 Channel = Channel & 0x0F;
 Channel = Channel << 2;
 ADCON0  = 0x03 | Channel;
unsigned int16 readADC ()
  unsigned int16 Value;
  ADCON0 = ADCON0 | 0x01; // turn on ADC
  delay_ms(5);
  ADCON0 = ADCON0 | 0x02;  //start conversion stel 2de bus
  while ( ADCON0 & 0x02 );
  Value = ADRESH;
  Value = ( Value << 8 ) | ADRESL;
  return Value;
//                                          LEES PIR
unsigned int8 readSensor()
   unsigned int8 adcValue;
   setChannel(0);
   delay_ms(15);
   adcValue = readADC();         // get ADC value from the sensor;
   return adcValue;
//                              skryf na eeprom
// Writes to the slave board from the master.
void write_ext_eeprom(int16 ADDRESS, unsigned char data)
   int8 status;
   i2c_start();
   i2c_write(0xAE);
   i2c_write((int8)(ADDRESS>>8));
   i2c_write((int8)ADDRESS);
   i2c_write(data);
   i2c_stop();
   //delay_ms(5);   delay is boarderline to the maximum waiting period - delay only if...do
      do
             i2c_start();
             status=i2c_write(0xAE);
              }   while (status != 0);
//                              LEES
// Read from the slave board and display the data.
unsigned char read_ext_eeprom( int16 ADDRESS )
   unsigned char data_read;
   i2c_start();
   i2c_write(0xAE);
   i2c_write( (int8)(ADDRESS>>8));
   i2c_write( (int8)ADDRESS);
   i2c_start();
   i2c_write(0xAF);
   data_read = i2c_read(0);
   i2c_stop();
   delay_ms(5);
   return data_read;
//                This function will read a single log from the EEPROM and store it in a intelli light structure
void readEE(unsigned int16 ee_address , ilINFO *currentEntry)
   // Move to correct block
   ee_address = ee_address * EE_BLOCK ;
   // Read EEPROM
   currentEntry->PIR_mod  = read_ext_eeprom(ee_address);                       // Day
   printf(read_ext_eeprom(ee_address));
      currentEntry->LDR_mod  = read_ext_eeprom(ee_address+1);
   printf(read_ext_eeprom(ee_address+1));
   currentEntry->temp_mod = read_ext_eeprom(ee_address+2);
    printf(read_ext_eeprom(ee_address+2));
   currentEntry->coil_mod[0] = read_ext_eeprom(ee_address+3);
   printf(read_ext_eeprom(ee_address+3));
   currentEntry->minute = read_ext_eeprom(ee_address+4);                     //Stuur minute
   printf(read_ext_eeprom(ee_address+4));
   currentEntry->hour = read_ext_eeprom(ee_address+5);                        //Stuur ure
   printf(read_ext_eeprom(ee_address+5));
   currentEntry->day = read_ext_eeprom(ee_address+6);                        //Stuur dae
   printf(read_ext_eeprom(ee_address+6));
   currentEntry->month = read_ext_eeprom(ee_address+7);                     //Stuur maande
   printf(read_ext_eeprom(ee_address+7));
//                         This function will log a single intelli light structure to EEPROM
void logtoEE(unsigned int16 ee_address, ilINFO *currentEntry)
   ee_address = ee_address * EE_BLOCK;
   // Write EEPROM
   write_ext_eeprom(ee_address,   currentEntry->PIR_mod);                // Day
   write_ext_eeprom(ee_address+1, currentEntry->LDR_mod);              // Hour
   write_ext_eeprom(ee_address+2, currentEntry->temp_mod);           // Temprature(High byte) >> 8
   write_ext_eeprom(ee_address+3, currentEntry->coil_mod[0]);
   write_ext_eeprom(ee_address+4, currentEntry->minute);
   write_ext_eeprom(ee_address+5, currentEntry->hour);
   write_ext_eeprom(ee_address+6, currentEntry->day);
   write_ext_eeprom(ee_address+7, currentEntry->month);
//                     Hier binne moet dit log as switch time verander
void light_on(int8 motionsensor)
   if(motionsensor > 0)
            output_high(PIN_C2);
            intelliINFO.coil_mod[0] = 1;
            ++RecordNr;                              //Record number increment to save continiously
             logtoEE(RecordNr, &intelliINFO);                // A '&' indicates the compiler we want to pass the address of the struct
   if(motionsensor == 0)
            output_low(PIN_C2);
            intelliINFO.coil_mod[0] = 0;
void readReference( unsigned int16 recordNUMBER )
ilINFO currentEntry;
readEE (recordNUMBER, &currentEntry);
void setup()
 set_tris_a(0x27);               // Port A Direction
   // RA0 : Sensor Input (1)
   // RA1 : Sensitivity Input (1)
   // RA2 : Sensitivity (1)
   // RA3 : Not used (0)
   // RA4 : Not used (0)
   // RA5 : LDR (1)
   set_tris_b(0x00);               // Port B Direction
   // RB0 : Not used (0)
   // RB1 : RS-485 Direction Output (0)
    // RB2 : LED1 Output (0)
   // RB3 : LED2 Output (0)
   // RB4 : LED3 Output (0)
   // RB5 : RUN LED Output (0)
    // RB6 : Not used (0)
   // RB7 : Not used (0)
   set_tris_c(0x80);               // Port C Direction
   // ADC Setup
    setup_adc_ports( AN0_AN1_AN2_AN3_AN4 );                            //sets port A to analogue
    setup_adc( ADC_CLOCK_INTERNAL );                        //enables the a/d module
    setupADC();
   setup_timer_2(T2_DIV_BY_4,155,2);
//                                       Main Program!!!!
// Main Program
   setup();
   SWITCH_TIME = 5;
   // Main Loop
   PIR = readSensor();                             //Lees die bewegings sensor
   light_on(PIR);
   intelliINFO.PIR_mod  = PIR;                    // PIR sensor
      intelliINFO.POT_mod  = 2;
   intelliINFO.LDR_mod =  3;
     intelliINFO.temp_mod = 4;
   intelliINFO.coil_mod[0] = RELAY;
   if( RecordNr == 10)
         readReference(1);
//                                          TIMEOUT!!!!!!
#INT_TIMER2
void isr_TIMER2()      //interrupt routine when overflow occurs in TIMER2. ====> VIR TIMEOUT
 static unsigned char ticks = 0;
   if(++ticks == 3)         // 1 millisecond
      // Software Clock
      if(++now.ms == 1000)    // One second elapsed
         now.ms = 0;
         if(++now.ss == 60)   // One minute elapsed
           now.ss = 0;
            if(++now.mm == 60)   // One hour elapsed
               now.mm = 0;
               if(++now.hh == 24)   // One day elapsed
                  now.hh = 0;
            if((++now.day == 31 && (now.month==4 || now.month==6 || now.month==9 || now.month==11 ))
              || (now.day == 32)
              ) {now.month++; now.day = 0;}
      ticks = 0;            // Reset ticks
   intelliINFO.minute = now.mm;
   intelliINFO.hour = now.hh;
   intelliINFO.month = now.month;
   intelliINFO.day = now.day;
