1000BPS using USE RS232
selvaraju
PostPosted: Tue Oct 02, 2007 3:42 am     Reply with quote
Hi everyone,
I need to interface my PIC16F877 to another device which is using 1000BPS baud-rate. I am using a 4Mhz crystal.
Please let me know how I can change my baud-rate setting to 1000Bps using the USE RS232 directive.
Looking forward to your earliest reply.
Thanks.
Selva
inservi
PostPosted: Tue Oct 02, 2007 4:03 am     Reply with quote
Here is the essential 'header' for timing. You need to add other fuses as you need. Check the rs232 parameters as xmit and rcv pin.
#include "16F877.h"
#device *=16  // if you want
#FUSES XT                       //Crystal osc <= 4mhz
.. other #fuses
#use rs232(baud=1000,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
In fact, is simple as giving the right #use delay() and baud=1000.
Best regards,
dro.
in médio virtus
