Is there a way to enable weak pullups on selected port B pins?
Specifically I would like to have a weak pull up on RB1 (pin22) only of a 16F877A.
Thanks.
Posted: Thu Sep 27, 2007 11:40 am
The data sheet says this:
Each of the PORTB pins has a weak internal pull-up.
A single control bit can turn on all the pull-ups.
This is performed by clearing bit RBPU (OPTION_REG<7>).
The weak pull-up is automatically turned off when the
port pin is configured as an output. The pull-ups are
disabled on a Power-on Reset.
Cuffy
Pullups on individual port B pins
Posted: Thu Sep 27, 2007 11:54 am
Thanks for the quick reply. I did see that in the spec. I am hoping that somewhere out there lies a clever solution.
SherpaDoug
Posted: Thu Sep 27, 2007 1:27 pm
Does that imply you could turn on pull-ups for the port, and then turn off all but RB1 by making those pins temporarily outputs? It might be worth a try. If it works please let us know, and comment your code thoroughly so you will know what you were doing a few years down the road! _________________ The search for better is endless. Instead simply find very good and get the job done.
Posted: Thu Sep 27, 2007 1:42 pm
No. If you make the pin into an output and then put it back to an input
the pull-up will be enabled again. There is no trick way to fool the
PIC. It works as stated in the data sheet.
