Guest1111 Guest
Another bisarre float behavoir |
Posted: Thu Sep 27, 2007 8:09 am |
The below code show -1912.492032 (LCD module)
but it's correctly memory stored (inspecting it with the debugger)
PCHW 3.249
any aidea?
Code: | #include <18f452.h>
#fuses HS, NOWDT, PUT, NOLVP, BORV27, NOPROTECT, CCP2B3
/* frecuencia del cristal del sistema */
#use delay(clock=10000000)
#include <lcd.h>
main()
float a = 2382.465;
lcd_init();
printf(lcd_putc,"%f",a);
while(TRUE);
Posted: Thu Sep 27, 2007 8:27 am |
Simple answer.
This is a 'known' bug with using %f, without a width specifier. Has been discussed here many times. Just limit the output width (so something like %6.3f), and it'll work OK.
