Hi everyone,
i want to create a frequency that starts from 100hz and ends at 5hz when i press a pushbutton.the duration between start and end is 30 sec.i am using pic16f84a and want to use timer0 for this purpose.i am using ccs compiler version 4.020
i have no idea about using timers and interrupts.
can anyone give me a proper guidence from where i start.
have anyone any example.
kender
Posted: Wed Sep 26, 2007 5:17 pm
A lot of example code come with CCS compiler. The files are installed into C:\Program Files\PICC\Examples directory. The descriptions of the examples are here – http://www.ccsinfo.com/devices.php?page=exlist
To start using timer, you should, probably look at the EX_STWT.C example. _________________ Read the label, before opening a can of worms.
hayee
Posted: Wed Sep 26, 2007 10:40 pm
Thanks kender.
i have already saw the examples but i am still confused
how to use timer and interupts.can anyone have easy way/method from which i can understand.
SherpaDoug
Posted: Thu Sep 27, 2007 7:48 am
I would create a "numerically controlled oscillator" for this. Since you just want a square wave output you don't need any waveform lookup table. You just need to add another register for the delta frequency per computation cycle.
A few years ago I wrote one for a 16C58 running at 20MHz that synthesized a sonar burst between 24kHz and 32kHz, so working below 100Hz should be easy. _________________ The search for better is endless. Instead simply find very good and get the job done.
