push button
eng/ IBRAHIM
push button
PostPosted: Mon Sep 24, 2007 2:16 am     Reply with quote
we need code for this(16f877)
when I push the button once, led go to high.
when I push the button again, led go to low.
umka
PostPosted: Mon Sep 24, 2007 4:14 am     Reply with quote
this is really simple code. you should try it yourself if you want to learn something. post your code and people will help correct it if its wrong
eng/ IBRAHIM
push button
PostPosted: Mon Sep 24, 2007 5:35 am     Reply with quote
i try this code
if(input(pin_d2))
output_high(pin_b6);
delay_ms(300);
if(input(pin_d2))
output_low(pin_b6);
delay_ms(300);
but the led is on&off when pushed continus.and the time not stable
i need the led on when pushed, led off when pushed agin not depending on the time off push
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Sep 24, 2007 6:32 am     Reply with quote
Something like this might work: (this code is not tested)
main()
   int1 oldState = 0, newState = 0;
   output_low(PIN_B6);
      newState = input(PIN_D2);
      if ((oldState == 0) && (newState == 1)
         output_toggle(PIN_B6);
      oldState = newState;
      delay_ms(1);
But this is less efficient as using an interrupt, my advice is to use the external interrupt and just to output_toggle when the interrupt happens.
SherpaDoug
Re: push button
PostPosted: Mon Sep 24, 2007 9:13 am     Reply with quote
Two points to fix the original code:
1) You need to wait for the button the be pressed, then you need to wait for it to be released.
2) Look up "debounce". When you close most any mechanical switch the metal contacts bounce, giving several openings & closings in a few milliseconds. You need to be careful when you consider the switch closed or opened.
inservi
PostPosted: Wed Sep 26, 2007 2:05 am     Reply with quote
Here is a clear document about debouncing: www.ganssle.com/debouncing.pdf
Personaly, the simple code :
if ( key is pressed ) {
  delay 50 ms
  wait while key is pressed
  delay 50 ms
is very well working every time!
Of course, some time, a timer can help to debounce without stop the working program with a delay as :
#define  INIT_debounceTime (a value for autorepeat key)
#INT_TIMER0
void TIMER0_isr(){
  if ( debounceTime != 0 ) --debounceTime ;
void main () {
 while( true ) {
    if ( key is pressed and debounceTime == 0 ) {
      debounceTime = INIT_debounceTime
in médio virtus
PostPosted: Wed Sep 26, 2007 11:02 am     Reply with quote
For questions like this, you should always use the forum's search page.
Search for: button
There are many posts with sample code. This thread has one that I did:
http://www.ccsinfo.com/forum/viewtopic.php?t=31849
Also search for: debounce
Here's a thread with sample code:
http://www.ccsinfo.com/forum/viewtopic.php?t=19874
eng/ IBRAHIM
PostPosted: Thu Sep 27, 2007 2:10 am     Reply with quote
Search for: button
many thank for all i use debounce and play good
