Sync_master/Slave
jjude
Sync_master/Slave
PostPosted: Wed Sep 26, 2007 12:23 am     Reply with quote
Run this code 16F87x?
Can i connect series 10 "slave machines" (master only send data, slaves only receive data)?
inservi
PostPosted: Wed Sep 26, 2007 1:23 am     Reply with quote
Do you mean serie or parallel ?
if the slaves are only receiving then you need a parallel bus.
i already make that in parallel with 1 master and 8 slave in a 'home made bus' like i2c. The distances was about 1.5 meter (5 foot) and about 200Khz.
i'm sure that must work with 10 slaves. If the fanout is not good you can use a small mosfet for buffering.
dro
in médio virtus
jjude
Example
PostPosted: Wed Sep 26, 2007 1:46 am     Reply with quote
I think CCS Complier examples Ex_Sync_Master.c and Ex_Sync_Slave.c.
