"mcr.c" driver.
Adria Zenq
"mcr.c" driver.
PostPosted: Thu Sep 20, 2007 5:49 am     Reply with quote
Dear PCM Programmer,
is possible apply the driver "mcr.c" for reading on any direction?
Thank you.
Adria Zenq
Re: "mcr.c" driver.
PostPosted: Tue Sep 25, 2007 2:05 pm     Reply with quote
I do modify the mcr.c code for read in any direction, but donĀ“t work with any magnetic card:
int mcr_read (char* track2=0x00)
   int   error        = 0;
   int1  dataBit      = 0;
   char  i=0;
   int1  LtoR=0, RtoL = 0;
   char  countbit     = 4;
   int1   reverse = 0;
   int1  set_one_time=0;
   int1  ST2      = 1;
   int1  ST2_old  = 1;
   int1  firstOne2= 0;
   int1  parity2  = 0;
   int   count2   = 0;
   int   index2   = 0;
   int   LRC2     = 0;
   while(input(MCR_CARD_PRESENT))
      LtoR=0;
      RtoL=0;
      index2=0;
      reverse=0;
      for(i=0;i<40;i++)
         Track2[i]=0x00;
   while(!input(MCR_CARD_PRESENT))
      if(track2 != 0 && index2 < 40)
         ST2 = input(MCR_STROBE2);
         if(ST2 == 0 && ST2_old == 1)
            ST2_old = 0;
            if(firstOne2 == 1)
               if(count2 == countbit)
                  count2 = 0;
                  if(reverse)
                     if(!input(MCR_DATA2))
                        bit_set(*(track2+index2), 0);
                  if(index2==0 && !LtoR && !RtoL && !set_one_time)
                     if(*(track2)==0x0B)
                        LtoR=1;
                        if(!LtoR && !RtoL)
                           index2=39;
                           RtoL = 1;
                           reverse=1;
                     set_one_time=1;
                  if(LtoR && !RtoL)
                     if(*(track2+index2-1) == '?' && LRC2 != *(track2+index2))
                        error |= MCR_ERR_LRC2;
                        LRC2 ^= *(track2+index2);
                     *(track2+index2) += 0x30;
                     if(!input(MCR_DATA2) != parity2 && *(track2+index2) != '0')
                        error |= MCR_ERR_PARITY2;
                     parity2 = 1;
                     ++index2;
//REVERSE DECODE
                  if(RtoL && !LtoR)
                     *(track2+index2) &= 0x0F;
                     --index2;
                  dataBit = !input(MCR_DATA2);
                  parity2 ^= dataBit;
                  if( !reverse )
                     if(count2==0)
                        if(dataBit)
                           bit_clear(*(track2+index2), 0);
                     if(count2==1)
                        if(dataBit)
                           bit_set(*(track2+index2), 1);
                           bit_clear(*(track2+index2), 1);
                     if(count2==2)
                        if(dataBit)
                           bit_set(*(track2+index2), 2);
                           bit_clear(*(track2+index2), 2);
                     if(count2==3)
                        if(dataBit)
                           bit_set(*(track2+index2), 3);
                           bit_clear(*(track2+index2), 3);
//REVERSE BITS
                  if( reverse )
                     if(count2==0)
                        if(dataBit)
                           bit_set(*(track2+index2), 4);
                           bit_clear(*(track2+index2), 4);
                     if(count2==1)
                        if(dataBit)
                     if(count2==2)
                        if(dataBit)
                     if(count2==3)
                        if(dataBit)
                  ++count2;
                  firstOne2 = 1;
                  ++count2;
         else if(ST2 == 1)
            ST2_old = 1;
   return error;
Somebody help me? Thanks!
