Hans Wedemeyer
Question about #build (reset=0X200, interrupt=0X208) |
Posted: Fri Sep 21, 2007 1:05 pm |
I'm trying to move the application reset vector and interrupt vectors out of the boot block.
#build(reset=0x200,interrupt=0X208)
#org 0X0, 0X1FF {} // don't use boot block
This compiles, but the interrupts are not working !
I just called CCS help and was told to use jump_to_isr() !
The latest help file has very little information on how to use this here is all it says: (with my comments:
int_global // what is this and where does it go ?
void global_isr(void) // does this replace the CCS generated isr handling ?
jump_to_isr(isr_address); // do I need to add a statement for every ISR ?
Lastly how do I get the address of the ISR ? is this done dynamically or at compile time ? |
Posted: Fri Sep 21, 2007 1:24 pm |
There's an example of its use in Ex_Bootloader.c.
It's in this location:
Hans Wedemeyer
Posted: Fri Sep 21, 2007 1:57 pm |
The example is not clear about what happens to the original isr dispatcher.
Does this new isr() replace the isr dispatcher ?
The value LOADER_END+5 seems to be specific to the ex_loader example.
But what address do I need to use ?
Is it 00208: GOTO 02CE // the isr dispatcher (from lst file)
This is not clear at all.
#int_global
void isr(void)
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
I'm lost ... |
Posted: Fri Sep 21, 2007 2:47 pm |
The compiler generates the normal dispatcher at the 0x208 address (this is what the 'build' statement tells it to do). You need to jump the physical interrupt, to this address, with the routine placed in the bootloader code.
Hans Wedemeyer
Posted: Fri Sep 21, 2007 4:16 pm |
Ttelmah wrote: | The compiler generates the normal dispatcher at th 0x208 address (this is what the 'build' statement tells it to do). You need to jump the physical interrupt, to this address, with the routine placed in the bootloader code.
Not sure I understand that.
The bootloader is a separate program from the actual application. Not sure I see the connection.
Lets say there is NO bootloader involved, and all I wanted was to operate the program with build (reset=0200, interrupt=0208) and code left out of the boot block.
Where does the jump_to_isr(address) go in the application code ?
Best regards
Hans W |
Posted: Sat Sep 22, 2007 2:09 am |
It doesn't.
To use interrupts, the bootloader, _must_ vector the interrupt jump, 'into' the real code. The following assumes only low priority interrupts are being used - otherwise two vectors come into play.
If you generate a program, with the build statement given, the compiler generates:
0x200 GOTO main_program_entry
0x208 The ISR handler
The hardware still generates a call to address 8 (this cannot be changed), so the bootloader needs to itself contain an 'int_global' handler, which just comprises a jump to address 0x208.
The bootloader code, must provide this relocation.
Hans Wedemeyer
Posted: Sat Sep 22, 2007 8:20 am |
Ttelmah wrote: | It doesn't.
Thanks for the explanation.
I now see the reason why top end boot loaders are more popular, almost no code changes to the loaded program but at the price of exposing one's code.
About the high priority interrupts: In the PIC18F6720 the High Priority interrupt vectors starts at 0x0008 and the Low at 0X0018 .
So if I understand this the should be another jump_to_isr( 0x0218) to cater for the Low priority interrupts.
Am I correct in that assumption ? |
Posted: Sat Sep 22, 2007 8:31 am |
Only if you are using both.
If interrupt priority is disabled, the 08 address is used.
Hans Wedemeyer
Posted: Sat Sep 22, 2007 8:47 am |
Ttelmah wrote: | Only if you are using both.
Yes I just noticed that.
I added #device HIGH_INTS=TRUE and tthe compiler generated this. To me it seems the one statement handles both.
Looks like the code handles the High Priority Interupts at 00008: GOTO 2008 and RETFIE's back into a few NOPs and then hits the low priority Interrupts and finally RETFIE's out at 0001C: RETFIE 0
I wonder if all those nop's are needed !
Thanks for the help I think I've got the hang of it now.
Best regards
Hans W
.................... void isr(void)
.................... jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
00008: GOTO 2008
0000C: NOP
0000E: NOP
00010: NOP
00012: NOP
00014: NOP
00016: NOP
00018: GOTO 2018
0001C: RETFIE 0 |
Posted: Sat Sep 22, 2007 9:45 am |
Yes.
The 'jump_to_isr' instruction will automatically handle both. This is the difference between using this, and a manual 'goto'.
What else are you going to put in the space between the jumps?. There is not enough space for any useable code, and nop is safe.
It doesn't "retfie back to the NOP's". When 'retfie' is executed at the end f the handler in the main code, the handler returns to where the interrupt occured. The address is on the stack.
The NOP's should never be executed.
Hans Wedemeyer
Posted: Sat Sep 22, 2007 4:48 pm |
Anonymous wrote: | Yes.
Thanks for the help. This bootloader is also working fine and code is protected from reads. |
