itzalak Guest
16F88 I2C master (software) and 16F88 Slave (hardware) |
Posted: Tue Sep 18, 2007 7:02 am |
Hello:
I've been looking for some days a solution for my I2C communication problem between two PIC16f88 Pics but I've found nothing to solve i yet so I decided to expose my problem.
As I said, there is a master PIC16F88 (software master) and other same pic as hardware slave. I'm tying to send a byte from master to slave but meanwhile the SPI (I2C) interrupt works fin I can't receive nothing. I can see that the state = i2c_isr_state() returns always 128 decimal.
My master code is as simple as this:
#use delay(clock=8000000)
#use i2c(Master,sda=PIN_B1,scl=PIN_B4,slow)
void main ()
reset_variables();
While(1)
mandar_codigo();
void reset_variables()
setup_adc_ports(sAN0|sAN1|sAN3|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL /*ADC_CLOCK_DIV_2*/);
setup_timer_0(T1_DISABLED /*RTCC_INTERNAL|RTCC_DIV_1*/);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
DISABLE_INTERRUPTS(GLOBAL);
#asm
MOVLW 0b00111011; //Module enable, clock
MOVWF 0x14; //SSPCON
#endasm
i2c_start();
delay_us(100);
i2c_write(0xA0);
delay_us(100);
i2c_write(0xAA);
delay_us(100);
i2c_write(0x55);
delay_us(100);
i2c_stop();
delay_ms(2000);
And the slave code is the next one:
#use I2C(slave,SDA=PIN_B1,SCL=PIN_B4,force_hw,slow,address=0xAA)
BYTE a;
BYTE address, buffer[0x10];
#INT_SSP
void i2c_isr ()
BYTE incoming, state;
clear_interrupt(INT_SSP);
disable_interrupts(GLOBAL);
disable_interrupts(INT_SSP);
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
void main ()
reset_variables();
While(1)
enable_interrupts(INT_SSP);
setup_adc(ADC_OFF);
setup_spi(SPI_SLAVE|SPI_L_TO_H);
setup_timer_0(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ);
// HAY UN ERROR EN EL DATASHEET DEL 16F88 PARA CONFIGURAR
// EL I2C. LO ARREGLAMOS PONIENDOLO A MANO
#asm
MOVLW 0b00111110 ;Module enable, clock, 7 bits
#endasm
Posted: Tue Sep 18, 2007 1:21 pm |
The reason it doesn't work, is the slave is never addressed.
The address must be the first byte after the start. You are sending 'A0', while the slave has an address of 'AA'. Therefore there is never an address match.
itzalak Guest
Posted: Fri Sep 21, 2007 4:22 am |
I've tryed everything but nothing goes fine. I've used avery simple master code as you told. The slave cod is the ccs example code little bit modified for the pic16f88.
The firs thing I can see is that the interrupt occurs, ok. Then I dissable global and SPI interrupt at the first line. In main code I put on those again but the pic needs "a lot of time" to do an interrpt again, sometimes incusive some seconds. As I'm looking the sending data in the scope I think there is a problem on "interrupt secction".
The data received in (watching in debug mode) is only sometimes ok, but only afew times.
void main ()
reset_variables();
While(1)
mandar_codigo();
setup_vref(FALSE);
void mandar_codigo()
// Write the letter 'B' to the slave board.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
delay_ms(2000);
The 16F88.h library:
#include <16F88.h>
#device ICD=TRUE
#device adc=10
#FUSES INTRC_IO //Internal RC Osc
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use i2c(Master,sda=PIN_B1,scl=PIN_B4)
And the slve code:
#if defined(__PCM__)
#include <16F88.h>
#device ICD=TRUE
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,INTRC_IO
#elif defined(__PCH__)
#include <18F88.h>
#use i2c(SLAVE, SDA=PIN_B1, SCL=PIN_B4, FORCE_HW, address=0xA0)
void reset_var();
unsigned int8 address=0;
BYTE buffer[0x04];
#INT_SSP
void ssp_interupt ()
address = incoming;
void main ()
reset_var();
void reset_var()
unsigned int8 i=0;
for (i=0; i<0x04; i++)
buffer[i]=0;
Any idea?
Thanks a lot for all your help. |
