whung.john Guest
triac gate question |
Posted: Tue Sep 18, 2007 5:27 am |
hi my friends, how are u .
i try to write a control AC fan program.
but i put key(pin_b1) and the ac fan have operate.
i put other key (pin_b3) and ac fan not turn speed.
fan motor turn not smooth in slow and fast.
PLEASE TELL ME WHAT ERROR AND HOW TO MODIFY
THANKS U VERY MUCH
AC fan is 110V AC AND 60hz.
1/60hz=16.67ms 16.67/2=8.335ms
the theread follow as:
#include <16F73.h>
#FUSES NOWDT, XT, NOPUT, NOPROTECT, NOBROWNOUT
BYTE dczero_flag=0;
BYTE control_motorkey=0;
unsigned int dcspeed;
#INT_TIMER0
void timer0_isr(void)
int16 dc_count;
output_high(pin_a1); //the triac can active and my u pin_a1 pin
set_timer0(255);
if (DC_count++==dcspeed)
output_low(pin_a1);//the triac NO active and my u pin_a1 pin
dc_count=0;
control_motorkey=1;
dczero_flag=1;
disable_interrupts(INT_timer0);
if (!input(pin_b1)) //SET on AC FAN
control_motorkey=1;
dczero_flag=1;
dcspeed=8000; //first fan speed is slower
if (!input(pin_b2)) //SET off AC FAN
control_motorkey=0;
dczero_flag=0;
if (!input(pin_b3)) //SET AC FAN fast
control_motorkey=1;
dczero_flag=1;
dcspeed=6000; //first fan speed is fast
if ((input(PIN_A4))&& (control_motorkey==1)&&(dczero_flag==1))
//find zero point
dczero_flag=0;
control_motorkey=0;
enable_interrupts(INT_timer0);
Posted: Tue Sep 18, 2007 6:07 am |
Code: | dcspeed=8000; //first fan speed is slower | dcspeed is an 8 bit integer and can't hold these large values. Change to an int16.
Declared like this the variable will loose it's value on exiting the interrupt. Declare it static if you want to keep the value.
Why do you do this? If timer0 is running in 8 bit mode it will fire again before you have time to exit the interrupt handler.
- Where is your setup code for timer0?
- Your interrupt is not working because you never call enable_interrupts(GLOBAL).
- dccount is never initialized.
- It's nice to disable the TRIAC at program startup.
- Your off-switch will not stop the motor when the TRIAC timer is still counting.
I might have missed an error... |
Posted: Tue Sep 18, 2007 6:52 am |
I don't see how your zero crossing detection works, not enough description. You need to start counting at the zero crossing to be consistent.
I set an external interupt to fire at the zero crossing by sampling the line voltage with a large resistor in series with the input pin clamped by a diode. Then reset the timer count on high to low transitions.
Microchip has an app note on this method. The only difference in my application was I used an opto-isolator between the line(120V.ac) and the pic. |
whung.john Guest
lose some code in program |
Posted: Wed Sep 19, 2007 10:20 am |
ckielstra wrote: | Code: | dcspeed=8000; //first fan speed is slower | dcspeed is an 8 bit integer and can't hold these large values. Change to an int16.
hi .Ckielstra
in my program lose post some code.
so i post apain
follow as :
setup_counters( RTCC_INTERNAL, RTCC_DIV_1);
disable_interrupts(INT_timer0); //first,let timer0 no operate,wait for other command
control_motorkey=1;
dczero_flag=1;
control_motorkey=0;
dczero_flag=0;
control_motorkey=1;
dczero_flag=1;
//find zero point
dczero_flag=0;
control_motorkey=0;
i have write a small program again.
and test ac motor can operate and can operate smooth.
ac motor ouput voltage is 100V.
in my old program ,where has some bug ?
let the motor can't operate smooth.
please teach me ,thanks u very
follow as :
#include <16F73.h>
if (input(PIN_A4))
delay_us(7200); //delay_us(7200) fast,delay_ms(8320) slow
delay_us(400); //delay_us(400) is fast set,delay_us(0) is slow
output_low(pin_a1);
delay_us(200); //delay_us(200) is fast set,delay_us(0) is slow
WHUNG.JOHN Guest
hardware set |
Posted: Wed Sep 19, 2007 10:32 am |
Anonymous wrote: | I don't see how your zero crossing detection works, not enough description. You need to start counting at the zero crossing to be consistent.
my friend. guest
u teach set an external interupt to fire at the zero crossing by sampling the line voltage with a large resistor in series with the input pin clamped by a diode.
my hareware ready have addtion electric parts.
and i send to my electric friends to confirm hareware no error.
he say my software maybe have bugs.
because he dont understand software .
so i must help from other.
thanks u very much . and send a good information for me.
can u find other my code bug again?
wait for u solve .thnks u again.
good nignt. |
