Code how to drive 40-Segment LED Bar Display Board
The Puma
PostPosted: Thu Sep 13, 2007 2:37 pm     Reply with quote
Can someone help me to drive this board (see link below)
Is it possible to drive it with SPI commands?
Please give me a simple example
Lets say the first led on the second led bar must lit
http://www.sure-electronics.net/mcu,display/DE-DP011.pdf
kevcon
PostPosted: Thu Sep 13, 2007 2:51 pm     Reply with quote
Dude,
there is PIC code right in the datasheet what more do you need?
The Puma
PostPosted: Thu Sep 13, 2007 3:21 pm     Reply with quote
What must i change to use it with CCS-C
void SEG_Shift3(void)
unsigned char i;
position++;
for(i = 0;i < (40-position); i++)
DATA = 1;
CLK = 0;
CLK = 1;
for(i = 0;i < position; i++)
DATA = 0;
CLK = 0;
CLK = 1;
if(position>40)position=0;
[/code]
inservi
PostPosted: Fri Sep 14, 2007 3:35 am     Reply with quote
here is just an example, there are some other way to adapting.
#define Fuc_key  PIN_B3
#define DIMM     PIN_B2
#define CLKpin   PIN_B1
#define DATApin  PIN_B0
int position ;
void SEG_Shift3(void) {
 unsigned char i;
  position++;
  for(i = 0;i < (40-position); i++) {
    output_high(DATA) ;
    output_low(CLK);
    output_high(CLK);
  for(i = 0;i < position; i++) {
    output_low(DATA) ;
    output_low(CLK);
    output_high(CLK);
An other way:
#define DIMM     PIN_B2
#define DATA(x) output_bit(DATApin, x)
#define CLK(x) output_bit(CLKpin, x)
int position ;
 unsigned char i;
 position++;
    DATA(1) ;
    CLK(0);
    CLK(1);
    DATA(0) ;
    CLK(0);
    CLK(1);
dro.
in médio virtus
The Puma
PostPosted: Fri Sep 14, 2007 6:48 am     Reply with quote
Ok, thx i will play with it
The Puma
PostPosted: Sat Sep 15, 2007 2:08 pm     Reply with quote
Ok, i have it working
This lit up the leds from right to left
then it clears the leds
But i need the following routine:
let say i must lit the led no 8
Can i made a routine the swith a led (on or off) whrn i give a ledno as parameter ( 1...40)
Please can someone help me
for(i=0;i<40;i++) {
output_high(DE_DP011_DATA);
output_low(DE_DP011_CLK);
delay_us(50);
output_high(DE_DP011_CLK);
delay_us(50);
for(i=0;i<40;i++) {
output_low(DE_DP011_DATA);
delay_us(50);
delay_us(50);
The Puma
PostPosted: Sun Sep 16, 2007 3:32 am     Reply with quote
The hardware is the following:
It has 4 x led matrix ( 10 leds/bar) controlled by 5 x 74HC164
My question is now, how can i switch led 15 on?
There must be an easer method to do that than below
DE_DP011_send_byte(0);
DE_DP011_send_byte(64);
Now must i send 5 times the send_byte procedure with the correct value
Can i made a procedure and gives as parameter the ledno that will lit
Another nice program where it to display the value of the ADC(PIC) to the ledbar.
In steps of 1024(5volts)/40(leds) = 26
a value below 26 most lit no led, a value >26 and <52 must lit led1 and so on
The source sofar is the this:
#include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#include <de_dp011.h>
   DE_DP011_init();
   while(TRUE) {
      DE_DP011_send_byte(1);
#ifndef DE_DP011_SELECT
#define DE_DP011_SELECT  PIN_C0
#define DE_DP011_CLK     PIN_C3
#define DE_DP011_DATA    PIN_C5
void DE_DP011_init() {
   output_high(DE_DP011_SELECT);
void DE_DP011_send_byte(BYTE data) {
   BYTE i;
   for(i=0;i<8;i++) {
      if((data&0x80)==0)
   shift_left(&data,1,0);
The Puma
PostPosted: Wed Sep 19, 2007 9:47 am     Reply with quote
Can nobody can help me or give me a hint to do that?
