i need to gen the 50HZ frq using TIMER0\1
pandi
PostPosted: Mon Sep 17, 2007 3:04 am     Reply with quote
i need 0 gen the 50HZ frq using timer0\1 for inverter application....
that means i gen the 50Hz sinewave output
anestho
PostPosted: Tue Sep 18, 2007 4:07 am     Reply with quote
Using a timer interrupt, you can generate a 50Hz square wave NOT sine.
fedetouz
PostPosted: Tue Sep 18, 2007 6:45 am     Reply with quote
you need a dsPIC for generate 50Hz sine function.
Hans Wedemeyer
Do it this way
PostPosted: Tue Sep 18, 2007 10:01 am     Reply with quote
Construct a 256 (or 1024) lookup table with the approximate sine values.
Then select a PIC chip that has a hardware PWM and then feed the PWM registers with the values form the lookup table.
Read the table and stuff the value the PWM registers every 20mS/NVILT NVILT is Number Of Values In Lookup Table. Use a Timer to trigger next feed !
pquedo code:
global int1 Feed;
Timer ISR ()
Feed=1; // the ONLY thing you do in the timer ISR
int main()
int16 index=0;
while( !Feed){;} // wait for next feed time
Set_PWM ( SineLookup[index] );
Feed=0;
// manage the index at 50Hz we have plenty of time even if it's a 4MHz system
index++;
if(index >= 1024)
index=0;
Adjust the timer period to adjust the frequency.
For 50Hz this works very well.
Of course the sine wave will be crude with small steps which is plenty good enough for DC-AC converter, if you filter the output a little you can get a better looking sinewave.
good luck
hans w
