Pic16F688 HW UART bit=7 question
Briartek
PostPosted: Wed Sep 12, 2007 3:26 pm     Reply with quote
WHen i use the following directive, rs232 reads work fine:
#use rs232(baud=1200,parity=O,xmit=PIN_C4,rcv=PIN_C5,bits=7,stream=RT,FORCE_SW,ERRORS)
When i remove the FORCE_SW,
#use rs232(baud=1200,parity=O,xmit=PIN_C4,rcv=PIN_C5,bits=7,stream=RT,ERRORS)
or
#use rs232(baud=1200,parity=O,xmit=PIN_C4,rcv=PIN_C5,bits=7,stream=RT,DISABLE_INTS)
or
#use rs232(baud=1200,parity=O,xmit=PIN_C4,rcv=PIN_C5,bits=7,stream=RT,DISABLE_INTS,ERRORS)
trying to use the HW uart, no interrupts, it no longer works. The only thing i could think of was the HW uart does not support the bits=7. Any thoughts?
PostPosted: Wed Sep 12, 2007 3:47 pm     Reply with quote
See Ttelmah's post in the middle of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=31506
