16f877A LCD interface
HOHOHAHA
PostPosted: Mon Sep 10, 2007 6:12 am     Reply with quote
hello , I am using 16f877A and trying to interface it with an LCD(2X16) HD44780 compatible. My CCS version is : 4.023. I used the driver posted by "PCM" (Flex_lcd.c), but used different config. pin.
#include <16F877A.h>
#device adc=8
#FUSES HS                     //Resistor/Capacitor Osc with CLKOUT
#include "LCD1.c"
   long int i;
   //char name;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
  lcd_init();
   set_tris_b(0x00);
   output_b(0x00);
   lcd_putc("\fHello World !");
   delay_ms(2000);
   for(i=100;i<=255;i++)
   printf(lcd_putc,"\fvalue %ld looks \nlike :%c",i,i);
   delay_ms(700);
   lcd_putc("\n Hello India !!");
   output_b(0xff);
    lcd_putc("\b");
the PIN conf that I used was...
D0 - E
D1 - RS
D2 - R/W
D4 - D4
D5 - D5
D6 - D6
D7 -D7
BUT the problem arises here .... the LED(TRIS_B = 0x00) does not blink and I found that as I disconnect D0 of my PIC to LCD(enable) the program starts executing, but making the connection again D0 goes LOW and program stops executing.
But at last the everything was alright as I used the default PIn conf. given by PCM
#define LCD_DB4   PIN_D0
#define LCD_DB5   PIN_D1
#define LCD_DB6   PIN_D2
#define LCD_DB7   PIN_D3
#define LCD_E     PIN_A1
#define LCD_RS    PIN_A3
#define LCD_RW    PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   1
can any one plz explain what is the problem ?
PostPosted: Mon Sep 10, 2007 11:24 am     Reply with quote
Check the pin connections on your board. Make sure they are correct.
Check the LCD driver file. Make sure the pin list is correct. Don't leave
the old pin settings in the driver. Delete the old #define statements
and just put in your new #define statements for the pins.
