adc pic16f877a not has stopped working!
kein
PostPosted: Fri Sep 07, 2007 8:10 am     Reply with quote
The following codes prints zero even when Vref+ is set to vdd(5v) and vref- set to ground(vss). why isn't it working? any idea?
#include <16F877A.h>
#device *=16
#device adc=10
#FUSES HS                       //High speed Osc (> 4mhz)
#include <KBD.C>
#include <ctype.h>
#include <float.h>
#include <math.h>
#include <string.h>
#include "LCD.c"
   long int adcValue;                    // 16-bit storage for ADC reading
   lcd_init();
   setup_adc_ports(AN0_AN1_AN4_AN5_VREF_VREF);
   setup_adc(ADC_CLOCK_DIV_32);;
   setup_adc(ADC_OFF);
   lcd_goto_xy(1,1);                  // Type some characters and backspace   over them.
   lcd_put_c(" X      Y      Z");
   delay_Ms(1000);
   // TODO: USER CODE!!
      //AccelCalibrateXYZ();
       set_adc_channel(0);            // select the required channel
       delay_us(10);
       adcValue =read_adc();
       lcd_gotoxy(13,2);
       printf(lcd_putc, "%Lu ", adcValue);
      delay_ms(200);
     //return 0;
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Sep 07, 2007 8:23 am     Reply with quote
try commenting out the following line in your code:
setup_adc(ADC_OFF);
That might solve your problem
kein
it did solve the problem
PostPosted: Fri Sep 07, 2007 9:57 am     Reply with quote
it did solve the problem; thanks
