garincha Guest
PIC C Compiler |
Posted: Wed Feb 13, 2008 2:04 am |
hi,
i am beginner in PIC programming and i need advice, so please help me if you can.
i use CCS C compiler and everything is O.K. except .hex file.
when i compile my source code in CCS C compiler i got message
Output files: ERR HEX SYM LST COF PJT TRE STA
0 Errors, 0 Warnings
so, i suppose every thing is O.K.
but later when i use MPLAB IDE to making my project with Project>Project Wizard and building my project with Project>Build All i don't have .hex file of my CCS C project, and i have nothing to transfer to my PIC16F84 via IC-Prog.
in MPLAB, after i was building my project, appear OUTPUT WINDOW with notice ...BUILD SUCCEEDED(to the end)...
during Project Wizard in MPLAB i used a correct device,correct active toolsuite(CCS C Compiler for PIC10/12/14...),i added existing file to my project("name".c) but i don't have .hex file and i need that:-).
Please, could someone tell me what i doing wrong, and if exists another way to generate hex file "from source code".c, please let me know.
thank You very much,
garincha[/u] |
Posted: Wed Feb 13, 2008 11:23 pm |
Try to run the compiler directly with the CCSC.exe file.
1. Open a Command Prompt (DOS) window.
2. Change to the c:\Program Files\Picc directory.
3. Type CCSC and press Enter. A small window will pop up.
4. Enter the full path to the source file. Example:
c:\Program Files\Picc\Projects\Test\Pcm_test.c
5. The click the OK button. The file should compile.
(If it says "IO Error", then you typed the wrong path or filename.)
Press Enter to make the CCS window go away.
6. Look in the project directory. The HEX file should be there. |
