#INT_EXT
Goto page 1, 2  Next
gg
#INT_EXT
PostPosted: Sun Sep 02, 2007 1:06 am     Reply with quote
i'm using 12F683 and I need to know if it is possible to use PIN interrupt (#INT_EXT) on other IO pins instead of pin 5. Pin 5 in the datasheet has "INT" label.
Because I want to use PWM output in my program, I need to free up pin 5. I also need ext interrupt so this is a problem for me.
Thanks.
PostPosted: Sun Sep 02, 2007 2:19 am     Reply with quote
Simple answer. No.
This is a problem of these very small chips. They have more abilities, than there are pins, and in some cases, using one ability, prevents another from being used. :-(
However, that having been said, there may be another solution. There is the 'pin changed' interrupt, which on this chip (unlike most others), is programmable on a 'per pin' basis. This will give you an interrupt on both the rising edge, and falling edge of the selected pin(s), and you will need to read the pin(s) in the interrupt handler to clear the event, and to find out which edge is being responded to. This interrupt can be setup/used, with the 'INT_RAx' definitions, where the 'x' selects the required pin. :-)
libor
PostPosted: Sun Sep 02, 2007 10:21 am     Reply with quote
There's also another option: You can use the built-in analog comparator ported on pins 6 and 7. It can trigger an interrupt when the voltage on one input crosses the other input's level. You can set the reference to the half of the supply voltage, and use the comparator's other input as a 'digital' PIN interrupt.
gg
PostPosted: Sun Sep 02, 2007 9:46 pm     Reply with quote
I did a search and found some example code
#include <12F683>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, NOMCLR
#use delay(clock = 8000000)
#use rs232(baud=9600, xmit=PIN_A1,rcv=PIN_A3)
#byte INTCON = 0x8B
#int_ra
void ioc_isr(void)
int8 c;
c = input_a();
output_high(PIN_A5);
int c;
c = input_a();
clear_interrupt(INT_RA);
clear_interrupt(INT_EXT);
// Then enable the interrupts.
enable_interrupts(INT_RA);
enable_interrupts(INT_EXT);
I tried this code but it doesn't seem to work. My test LED should light up when an interrupt breaks when I input a squarewave to RA4.
What is the problem?
Thanks.
gg
PostPosted: Mon Sep 03, 2007 12:17 am     Reply with quote
problem solved.
I didn't correctly setup the IO pins.
PostPosted: Mon Sep 03, 2007 2:29 am     Reply with quote
If you change it, so that the references to 'INT_RA', are to 'INT_RA4', then the compiler wll automatically add the bit masking, so this only responds to RA4, not any other pin. :-)
The comparator solution is another neat approach. Potentially allows three separate external interrupts on this chip.
Kova
PostPosted: Mon Sep 03, 2007 2:41 am     Reply with quote
I have the same problem.
I have a 12F683 pic with the:
-GP2 setted like PWM
-GP0 input (a switch)
-GP5 setted in output (a LED)
This is my code:
#include <12F683.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOPUT                      //Power Up Timer
#FUSES BROWNOUT               //No brownout reset
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#byte INTCON = 0x8B
#int_ra
void ioc_isr(void)
int8 c;
c = input_a();
set_tris_a(1);
enable_interrupts(INT_RA0);
   //36Khz
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,55,1);
   setup_ccp1(CCP_PWM);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ);
   set_pwm1_duty(27);
The PWM works until the GP0 switch is pressed Crying or Very sad
PostPosted: Mon Sep 03, 2007 3:25 am     Reply with quote
There is no interrupt handler for INT_EXT. Without a handler the interrupt is never cleared and the processor will forever process the interrupt.
Another few minor remarks:
This line is very late in your code. The code works because this line is not needed at all since you have a '#use delay' line as well which is doing the same thing.
   set_pwm1_duty(27);
You have to configure the timer and pwm routines only one time. Now you are wasting CPU power and there are some nasty side effects possible so move this out of the loop.
Kova
PostPosted: Mon Sep 03, 2007 4:20 am     Reply with quote
Sorry, which handler I can put under the INT_EXT tag?
In the 12F683 the external interrupt is on the same pin of PWM :(
Rolling Eyes Rolling Eyes
PostPosted: Mon Sep 03, 2007 5:14 am     Reply with quote
Get rid of the enable for INT_EXT.
If you enable an interrupt wthout a handler, and the interrupt flag gets set by any means, it hangs the processor in the global interrupt hadler. Now, the 12F683, has the internal 'INT' connection, made all the time, even if the pin is used for something else (the only exception is when the port is used as an analog input - look at Fig 4-3 in the data sheet). You are enabling this interrupt, which will get triggered by the PWM, and then have no handler, so the code will hang...
Kova
PostPosted: Mon Sep 03, 2007 8:44 am     Reply with quote
Without the INT_EXT tag the program no execute the INT_RA handle :( (the led connected to GP5 doesn't flash when I push the switch connected to GP0)
This is the code:
#include <12F683.h>
#device adc=8
#byte INTCON = 0x8B
#int_ra
void ioc_isr(void)
set_tris_a(1);
setup_adc(ADC_OFF);
setup_vref(FALSE);
set_pwm1_duty(27);
Thanks for the help ;)
PostPosted: Mon Sep 03, 2007 9:17 am     Reply with quote
You removed two instead of one line. restore the line
'Global' is not an interrupt by itself but more like a master switch, this single identifier disables or enables all selected interrupts.
Kova
PostPosted: Mon Sep 03, 2007 10:00 am     Reply with quote
It works perfectly.
Thanks a lot ;)
Kova
PostPosted: Tue Sep 04, 2007 1:31 am     Reply with quote
Kova wrote:
It works perfectly.
Thanks a lot ;)
This is my code.
The program change the frequency of PWM (duty is always 50%) only when the switch (GP0) goes on (VCC) . A led connected to GP5 invert its state when the switch is HIGH
#include <12F683.h>
#device adc=8
#byte INTCON = 0x8B
int ct=1;
#int_ra
void ioc_isr(void)
delay_ms(10); //Debounce
if (input(PIN_A0)
  switch(ct)
   case 0x00: //36Khz
         set_pwm1_duty(27);
         ct=1;
   case 0x01: //38Khz
         setup_timer_2(T2_DIV_BY_1,52,1);
         set_pwm1_duty(26);
         ct=2;
   case 0x02: //40Khz
         setup_timer_2(T2_DIV_BY_1,49,1);
         set_pwm1_duty(24);
         ct=0;
   output_toggle(PIN_A5); //Invert led
setup_oscillator(OSC_8MHZ); //Without this line the program doesnt works correctly (?)
set_tris_a(1); //Switch on GP0
//36Khz
setup_adc(ADC_OFF);
setup_vref(FALSE);
set_pwm1_duty(27);
gg
PostPosted: Tue Sep 04, 2007 10:19 pm     Reply with quote
When using other pins for INT such as RA4, what register do I look in to see if it is a rising or failling edge interrupt?
Goto page 1, 2  Next
Page 1 of 2
