Guille Guest
| How can I implement something like that in CCS C compiler |
Posted: Wed Sep 05, 2007 2:25 pm |
| Code: | typedef union{
unsigned int WORD[1];
unsigned char BYTE[2];
tData8bits BYTEbits[2];
}tData2bytes;
typedef union{
unsigned long DWORD[1];
unsigned int WORD[2];
unsigned char BYTE[4];
tData8bits BYTEbits[4];
}tData4bytes; |
I need to implement a code like that. |
Posted: Wed Sep 05, 2007 3:40 pm |
The variable name BYTE is not allowed in CCS as it is a reserved keyword, you will have to choose another name. Then, if you have to change the name of BYTE, it is a good idea to change the name of Word as well.
| Code: | typedef int8 tData8bits;
typedef union{
unsigned int myWORD[1];
unsigned char myBYTE[2];
}tData2bytes;
typedef union{
unsigned long myDWORD[1];
unsigned int myWORD[2];
unsigned char myBYTE[4];
}tData4bytes; |
You can do it, but it requires vs. 4 of the compiler to do the array of bits.
The program shown below displays the following output. It was tested
with vs. 4.053.
| Quote: |
12345678
12345678
12345678
12345678
Here is the demo program:
#include <16F877.h>
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
#use Delay(Clock=4000000)
typedef union
int32 dword[1];
int16 words[2];
int8 bytes[4];
int1 bits[32];
}t_32bits;
int8 i;
int32 temp;
t_32bits data;
data.dword[0] = 0x12345678;
printf("%lx\n\r", data.dword[0]);
printf("%lx%lx\n\r", data.words[1], data.words[0]);
printf("%x%x%x%x\n\r", data.bytes[3], data.bytes[2],
data.bytes[1], data.bytes[0]);
// Shift the bit array into a 32-bit variable and display it.
temp = 0;
for(i=0; i <32; i++)
shift_right(&temp, 4, data.bits[i]);
printf("%lx\n\r", temp);
