Measurement of pulsewidth at 10 ports
richi-d
PostPosted: Thu Aug 30, 2007 3:22 am     Reply with quote
I need to measure the pulsewith at 10 ports. I can do it for every single pin, but is there a better method to do it with a for()?
Example: while ( !input(EINGANG_i_1) ) (I know this won´t work, but you see what i mean...)
Here is the code for the single pin measurement:
#define   EINGANG_1_1      PIN_A4
#define   EINGANG_2_1      PIN_A5
#define   EINGANG_1_2      PIN_F2
#define   EINGANG_2_2      PIN_F3
#define   EINGANG_3_2      PIN_F4
#define   EINGANG_4_2      PIN_F5
#define   EINGANG_1_3      PIN_E0
#define   EINGANG_2_3      PIN_E1
#define   EINGANG_3_3      PIN_E2
#define   EINGANG_4_3      PIN_E3
long   IMPULSBREITE_[10];
void Komplettmessung (void)
   long   WERT_[2];
//PIN 1 /////////////////////////////////////////////////////////////////////////////
   WERT_[1] = 1;
   WERT_[2] = 0;
   while ( WERT_[1] != WERT_[2] )
      for (t=0; t<2; ++t)
         while ( !input(EINGANG_1_1) )
            NOP;
         SET_TIMER1(0);
         while ( input(EINGANG_1_1) )
            NOP;
         WERT_[t] = GET_TIMER1
   IMPULSBREITE_[1] = WERT_[1];
//PIN 2 /////////////////////////////////////////////////////////////////////////////
   WERT_[1] = 1;
   WERT_[2] = 0;
      for (t=0; t<2; ++t)
         while ( !input(EINGANG_2_1) )
            NOP;
         SET_TIMER1(0);
         while ( input(EINGANG_2_1) )
            NOP;
   IMPULSBREITE_[2] = WERT_[1];
to be continued.....
richi-d
PostPosted: Fri Aug 31, 2007 9:55 am     Reply with quote
Any ideas? I´m sure CCS has a solution...
PostPosted: Fri Aug 31, 2007 10:33 am     Reply with quote
If you ask a design question like this, you need to give us information
on the input signals and other issues:
What is the frequency of the input signals ?
Are they synchronous ? If so, on what edge ?
What is the expected range of the duty cycle ?
What accuracy is required in the pulse width determination ?
What PIC are you using ?
What is the oscillator frequency of the PIC ?
mskala
PostPosted: Fri Aug 31, 2007 11:48 am     Reply with quote
Look in the devices directory for your pic's .h file. In it they define all the PIN_A0, PIN_A1, ... names as numbers. It won't be understandable code, but you can use those numbers, either in a FOR loop if all pins happen to be sequential, or call a single routine with the pin number as parameter.
PostPosted: Mon Sep 03, 2007 1:24 am     Reply with quote
frequency: 50Hz
Synchron: no
duty cycle: 16ms low, 500ms - 2500ms high
acuracy: max. at 16MHz 0,25µs - a little offset doesn´t matter
Pic 18F452
Osc.: 16MHz
@mskala: I found the numbers in the .h file. Can I renumber them from 0- .... ?
richi-d
PostPosted: Mon Sep 03, 2007 1:26 am     Reply with quote
frequency: 50Hz
Synchron: no
duty cycle: 16ms low, 500µs - 2500µs high
Pic 18F452
Osc.: 16MHz
Sorry for double post - wrong pulsetime. They are from a receiver
richi-d
PostPosted: Tue Sep 04, 2007 2:34 am     Reply with quote
Thanks for the Tip with the numbers, it would work. But how can I change this numbers that they are all in a row?
For Exampe I want PIN_A0, PIN_A1, PIN_B3, PIN_B4, PIN_C5 and so on in a row:
#define PIN_A0  31744
#define PIN_A1  31745
#define PIN_A2  31746
#define PIN_A3  31747
#define PIN_A4  31748
#define PIN_A5  31749
#define PIN_A6  31750
#define PIN_A7  31751
#define PIN_B0  31752
#define PIN_B1  31753
#define PIN_B2  31754
#define PIN_B3  31755
#define PIN_B4  31756
#define PIN_B5  31757
#define PIN_B6  31758
#define PIN_B7  31759
#define PIN_C0  31760
#define PIN_C1  31761
#define PIN_C2  31762
#define PIN_C3  31763
#define PIN_C4  31764
#define PIN_C5  31765
#define PIN_C6  31766
#define PIN_C7  31767
better would be for me:
#define PIN_A0  32000
#define PIN_A1  32001//canged
#define PIN_B0  32002//canged
#define PIN_B1  32003//canged
#define PIN_C5  32004//canged
is this possible? I tried to simulate but it don´t work. Where do this numbers come from-where are the defined?
PostPosted: Tue Sep 04, 2007 2:46 am     Reply with quote
The numbers, are the memory address where the port is mapped, and the bit number _in_ this address, coded as address*8+bit_number.
These are set by the hardware of the chip. You cannot change them.
However consider a look_up table.
int16 port_to_use[] = {
Obviously with all the entries you want, in the order you want them.
Then to access the first port, just use:
output_high(port_to_use[0]);
Using a variable like this, will only work with the V4 compiler. However coe has been posted here in the past by a number of people (myself included), to give this behaviour with the old compiler.
richi-d
PostPosted: Tue Sep 04, 2007 4:49 am     Reply with quote
Perfect!! Thanks a lot...
