hayee
| have no one any solution for my question |
Posted: Sat Sep 08, 2007 1:37 am |
HI,everyone
I want to display the data on my lcd which is stored in the eeprom.
actually i am entering different numbers from keypad and the numbers are stored in eeprom.i am using LCD.c as a driver file and using PIC16F877A.my code is as follows
#include "eeprom.h"
#include "ctype.h"
#include "string.h"
char str[17];
char a[16]="TESTING EEPROM";
#define r1 PIN_B0
#define r2 PIN_B1
#define r3 PIN_B2
#define r4 PIN_B3
#define c1 PIN_B4
#define c2 PIN_B5
#define c3 PIN_B6
#define c4 PIN_B7
#include "lcd.c"
int key();
BYTE gethex();
BYTE gethex1();
BYTE i,address,value;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
SET_TRIS_B(0xF0);
// TODO: USER CODE!!
initLCD();
printStringXY_LCD(a,0,0);
do
printf("\r\n\n TESTING EEPROM:\r\n\n");
for(i=1;i<=3;i++)
printf(" %x",read_eeprom(i));
printf("\r\n\n LOCATION TO CHANGE:\r\n");
address=gethex();
printf("\r\n\n NEW VALUE:\r\n");
value=gethex();
write_eeprom(address,value);
BYTE gethex()
int hi,b,lo;
hi=gethex1();
if (hi!=255)
for(b=0;b<10;b++)
delay_ms(10);
continue;
lo=gethex1();
if (lo!=255)
for (b=0;b<10;b++)
delay_ms(10);
continue;
if (lo==221)
return(hi);
return (hi*16+lo);
BYTE gethex1()
char digit;
digit=key();
printf("%d",digit);
delay_ms(10);
return (digit);
int key()
output_bit(r1,0);
output_bit(r1,1);
delay_ms(10);
if (input(c1))
return (0x0a);
if (input(c2))
return (3);
if (input(c3))
return (2);
if (input(c4))
return (1);
output_bit(r1,0);
output_bit(r2,1);
delay_ms(10);
if (input(c1))
return (0x0b);
if (input(c2))
return (6);
if (input(c3))
return (5);
if (input(c4))
return (4);
output_bit(r2,0);
output_bit(r3,1);
delay_ms(10);
if (input(c1))
return (0x0c);
if (input(c2))
return (9);
if (input(c3))
return (8);
if (input(c4))
return (7);
output_bit(r3,0);
output_bit(r4,1);
delay_ms(10);
if (input(c1))
return (0x0f);
if (input(c2))
return (0x0e);
if (input(c3))
return (0);
if (input(c4))
return (0x0d);
output_bit(r4,0);
Posted: Sat Sep 08, 2007 2:57 am |
The reason your previous posts were ignored is because you need to
do the following things before you can get help from people:
1. Post your code with proper indentation and formatting, so it looks
good and is easy to read.
Post it in a "code block" to preserve the indentation. Use the Code
button to do this. Use the Preview button to check that it looks
correct (in a Code block) before you click the Submit button.
Make corrections and check it several times, if necessary.
2. Explain what parts of your program work properly, and what parts
do not work. Show the correct output that you would like to get
from the program, and show the "bad" output that you get now.
3. Tell us the manufacturer and part numbers of all devices that you
are using in your program (such as the keypad).
4. Post all #include, #fuses, and #use statements.
5. Post your compiler version. This is a 4-digit number such as 3.249,
4.013, or 4.054, etc. You can find it at the start of the .LST file,
which is in your project directory. |
