Covert a hex value to decimal value
The Puma
PostPosted: Sat Sep 01, 2007 9:55 am     Reply with quote
The output of the LTC1298 sample programs give for example
Ch0: 2.500v = 8000h
this value must be 800h and i must be converted to dec.
How can i do this?
PostPosted: Sat Sep 01, 2007 10:51 am     Reply with quote
atoi() requires the string to start with '0x'.
strtol() seems like a better choice.
You don't want to convert the last character? Then just replace it with a 0 when passing to strtol() so it becomes the end-of-string marker.
atoi() and strtol() are large functions because they are so versatile. If you are tight on memory you can have a look at axtoi(): http://www.ccsinfo.com/forum/viewtopic.php?p=679#679
The Puma
PostPosted: Sat Sep 01, 2007 10:56 am     Reply with quote
A long int value must converted to a decimal value
Please give a sample code for converting a long int to decimal number
long int = 8000
after conversion the dec is than 2047
The Puma
PostPosted: Sat Sep 01, 2007 11:35 am     Reply with quote
If have now this
convert_to_volts(data,volt_str);
   data=data>>4;
   lcd_gotoxy(1,2); printf(lcd_putc,"Ch0: %Sv %4LX",volt_str,data);
But the first value (volt_str) will not correct displayed
Why
