30f4013 and TC74A5 (SOLVED)
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Wed Apr 16, 2008 3:52 am     Reply with quote
Hello ,
i have a strange problem
I make a I2C connection to a TC74
the loop is working, bu i receive always a "0"
what could be wrong ?
#include <30f4013.h>
#device adc=10
#FUSES NOWDT // Watch Dog Timer
#FUSES EC
#FUSES PR //Promiary Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOCOE //Device will reset into operational mode
#FUSES ICS0 //ICD communication channel 0
#FUSES RESERVED //Used to set the reserved FUSE bits
#define XTAL_FREQUENCY 10000000
#use delay(clock=XTAL_FREQUENCY)
#use i2c(MASTER, SDA=PIN_F2, SCL=PIN_F3, FORCE_HW,slow)
#use rs232(stream = RS232, baud=115200,parity=N,xmit=PIN_F5,rcv=PIN_F4,bits=8)
   int data;
    int ack;
    int fahr;
Void main()
   set_tris_b(0xFFFF);
   While(1)
      i2c_start();
        ack = i2c_write(0x9A);
        ack = i2c_write(0x00);
        /* send start again */
        i2c_start();
        ack = i2c_write(0x9B);
        data = i2c_read(0);
        i2c_stop();
        printf("temp %D\r\n",data);
        delay_ms(200);
Carl
(edit)
Cleared Force_HW in the I2C(master settings....
