void Init_LCD( void ) // initialize LCD display
// 15mS delay after Vdd reaches nnVdc before proceeding with LCD initialization
// not always required and is based on system Vdd rise rate
Delay(Delay_15mS_Cnt); // 15ms delay
Error:
Executing: "C:\Program Files\PICC\Ccsc.exe" +FD "main_rtc.c" I+="C:\Microchip demo\h;C:\Microchip demo\other files" +DF +LN +T +A +M +Z +ICD +Y=0 +EA I+="..\h"
*** Error 112 "C:\Microchip demo\other files\lcd.c" Line 121(1,1): Function used but not defined: ... Delay SCR=985
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Apr 16 07:28:03 2008
I am using CCS C version 4.071 with MPLAB 8.00.
Ken
RLScott
Re: Does CCS C compiler support functional prototypes?
Posted: Wed Apr 16, 2008 5:54 am
The compiler did not issue any error about the functional prototype, so I think that is OK. What the error said was that the function was not defined. The functional prototype does not define a function. It only declares a function. You still have to supply the function code itself. That is the "definition" that is lacking.
