ralph79
| 16F688 and 16f627A issues |
Posted: Wed Aug 29, 2007 8:59 am |
I've been working with CCS compiler V4.0.038 and I have a very strange problem. I have basically the same code as you can you above for the 627A and for the 688. But with the 16F627 in the rs232 port I receive the same characters I send. But with the 688 the characters are all wrong. Does anybody know why is this happening?
Code for 627A
#include <16F627A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, NOCPD, PUT
#define max_buf_length 10
#use delay(clock=8000000)
#use rs232(baud=1200, parity=N, xmit=PIN_B2, rcv=PIN_B1, bits=8, errors)
int8 rcv_data[max_buf_length] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
int8 rcv_pointer = 0;
int8 pos_eeprom = 0;
short int values_rcv = 0;
#int_RDA // rs232 receive data available
void RDA_isr(void)
int8 ch = 0;
ch = getchar();
rcv_data[rcv_pointer++] = ch; // store data
if (rcv_pointer == 10)
values_rcv = 1;
int8 i = 0;
port_b_pullups(TRUE);
set_tris_b(0x01); // PIN_B1 as input
setup_vref(FALSE);
disable_interrupts(INT_RDA);
enable_interrupts(INT_RDA);
while (1)
if (values_rcv == 1)
for (i = 0; i < rcv_pointer; i++)
write_eeprom(pos_eeprom++, rcv_data[i]);
rcv_data[i] = 0; // cleaning the buffer
pos_eeprom = pos_eeprom + 2;
values_rcv = 0; // reset variables
rcv_pointer = 0;
Code for 688
#include <16F688.h>
#device *=16
#device adc=8
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR, NOBROWNOUT, NOCPD, PUT, NOIESO, NOFCMEN
#use rs232(baud=1200, parity=N, xmit=PIN_C4, rcv=PIN_C5, bits=8, errors)
void RDA_isr(void)
int8 ch = 0;
ch = getchar();
values_rcv = 1;
int8 i = 0;
port_a_pullups(TRUE);
set_tris_c(0x20); // PIN_C5 as input
setup_adc(ADC_OFF);
setup_comparator(NC_NC);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ);
while (1)
rcv_pointer = 0;
Any help will be appreciate
Thanks in advance |
SET
Posted: Thu Aug 30, 2007 9:04 am |
| Quote: | | Code: | | set_tris_c(0x20); // PIN_C5 as input |
I'm guessing you tried this in case the compiler wasn't setting Rx as an input? Shouldn't be required..
| Quote: | | But with the 16F627 in the rs232 port I receive the same characters I send. But with the 688 the characters are all wrong. |
Are you missing some code? Your code puts the Rx'ed chars in EEPROM, so maybe the problem lies there? |
ralph79
Posted: Thu Aug 30, 2007 9:21 am |
Thanks for your response.
The set_tris_a was my ultimate test. I know that it shouldn't be required but ... I've already try everything.
This code is just a very small part of complex program.
I receive the chars from a RF receiver and, for a test, I save them to the eeprom. With this I want to know if there are any differences between the characters that I send and characters I receive during the time. With the 16F627A I don't have any trouble. But with the 688 I can't get it to work properly.
Is there any other initialization or function that I need to put in my code do get this work? Or in other words what I missed?
Thanks |
