damaging 12f629
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
damaging 12f629
PostPosted: Wed Aug 29, 2007 10:42 pm     Reply with quote
Dear Sir,
here i am using 12f629, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
for testing only i did this simple programe,
#if defined(__PCM__)
#include<12F629.h>
#fuses INTRC_IO,NOWDT,PUT,NOMCLR,PROTECT,NOCPD,BROWNOUT
//Internal RC Osc, no CLKOUT,No Watch Dog Timer,Power Up Time ON,Internal MCLR,Code Protect ON,No EE protection,Brownout detect ON,
#use delay(clock = 4000000)   // INTERNAL 4 MHz FREQ.
void init_CPU();
    init_CPU();
      OUTPUT_HIGH(PIN_A0);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A0);
      DELAY_MS(500);
      OUTPUT_HIGH(PIN_A1);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A1);
      DELAY_MS(500);
      OUTPUT_HIGH(PIN_A2);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A2);
      DELAY_MS(500);
      OUTPUT_HIGH(PIN_A3);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A3);
      DELAY_MS(500);
      OUTPUT_HIGH(PIN_A4);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A4);
      DELAY_MS(500);
      OUTPUT_HIGH(PIN_A5);
      DELAY_MS(500);
      OUTPUT_LOW(PIN_A5);
      DELAY_MS(500);
void init_CPU()
   PORT_A_PULLUPS(0x00);
   SET_TRIS_A(0x00);            SETUP_COMPARATOR(NC_NC_NC_NC);
I was tested on this using bread-board. And at o/p i have connected LED
Here no led is flashig also it was damaging 12f629.
Any suggestion appriciated
Thank You,
With Best Regards,
Deepak.
PostPosted: Wed Aug 29, 2007 10:57 pm     Reply with quote
Do you have series resistors installed on each of the LEDs ?
You need them, to limit the electrical current to a safe level.
Try using 470 ohm resistors.
These are series resistors, not pull-ups.
Douglas Kennedy
PostPosted: Thu Aug 30, 2007 8:43 am     Reply with quote
You may have erased location 0x3FF that contains the internal OSC calibration value set at the factory. It needs a 0x34vv value where vv is the calibration (80 is the mid pt) and 34 a retlw instruction ex value 0x3480. I'm not sure if MPLAB protects this location but if it is erased the Internal OSC won't run.
