nilsener
Multiplex Digital Display and EEPROM |
Posted: Tue Aug 28, 2007 7:23 am |
PCH 4.014
18F2520
Dear,
I am driving a 3 Digit 7-Segment Display (888). To avoid visible flicker each of the 3 multiplex-pins is active for 2 ms using timer0 interrupt.
I am writing to internal EEPROM (approx. 10 write cycles) each 15 minutes to store the working hours of the unit and as one write cycle needs approx. 10 ms then I get visible flicker at the display for 100 ms. CCS seems to disable interrupts during write_eeprom(); and so the multiplexing is not working during this time.
has anyone an idea how to solve this problem?
Thanks for any help
Best Regards
nilsener |
SET
Posted: Tue Aug 28, 2007 8:29 am |
You might have to by-pass CCS code and write directly to the EEPROM, your code would write each byte at a time and poll for write completion - see the data sheet for details! (leaving Timer0 interrupt enabled).
It's a pity that Microchip dont have a capability for automatic and flexible timer reload, would be ideal for this sort of application without having to service interrupts - maybe in later PICs... |
Posted: Tue Aug 28, 2007 8:36 am |
Dear SET,
thank you for helping. Did I understand right that you recommend to make it without using the CCS write_eeprom() command? I think you mean that I have to make my own code in Assembler?
Best Regards
Nilsener |
SET
Posted: Tue Aug 28, 2007 8:43 am |
Maybe you wont need assembler (you can use #byte to map C variables to register addresses), but if CCS do indeed disable interrupts then you will have to write your equivalent to write_eeprom . Any else done this before? |
avro698
Joined: 11 Nov 2006 Posts: 9 Location: South Wales, UK.
Posted: Tue Aug 28, 2007 12:44 pm |
What size eeprom do you have?
Maybe it can be replaced with an FRAM (see www.ramtron.com)
This should improve/reduce access times - they advertise these parts as having 'NoDelay Writes'
698 |
SET
Posted: Tue Aug 28, 2007 3:22 pm |
Something like:
Code: | #byte EEADR = 0xFA9
#byte EEDATA = 0xFA8
#bit EECON1_EEPGD = 0xFA6.7
#bit EECON1_CFGS = 0xFA6.6
#bit EECON1_WREN = 0xFA6.2
#bit EECON1_WR = 0xFA6.1
void my_write_eeprom(int8 address, int8 value)
EEADR = address;
EEDATA = value;
EECON1_EEPGD = 0;
EECON1_CFGS = 0; // Access EEPROM
EECON1_WREN = 1; // Enable writes
disable_interrupts(GLOBAL); // Disable Interrupts for 'special sequence'
EECON2 = 0x55; // required sequence
EECON2 = 0xAA;
EECON1_WR = 1; // Set WR bit to begin write
EECON1_WREN =0; // Disable writes on write complete (EEIF set)
This is from the PIC18F2420 family datasheet, but should be similar to others. Just make sure you dont attempt to write the bytes too quickly - if you have a small delay (say 10mS) between each write then that will allow your timer interrupt code to run. |
