"Expected =" Compiler Error at beginning of interr
EJensen
PostPosted: Wed Jun 06, 2007 7:32 am     Reply with quote
I am using a 16F87 PIC. I need an interrupt on overflow, so I am using the TIMER1 overflow interrupt. The problem I am encountering is a "Expected =" right at the beginning of the interrupts function call.
#int_TIMER1
void TIMER1_isr() <- "Expected =" error here
If you need me to post any extra code or information, I'll be happy to do so.
Thanks,
EJensen
rnielsen
PostPosted: Wed Jun 06, 2007 8:25 am     Reply with quote
Please post the interrupt routine so we can see what's going on with it.
PostPosted: Wed Jun 06, 2007 9:09 am     Reply with quote
Most likely the error is in one of the lines just before the indicated line.
EJensen
PostPosted: Wed Aug 29, 2007 7:45 am     Reply with quote
Aaaaah, ckielstra you are correct.
The error was in the last line of my include file. The #include directive being just before the line indicated in the error message.
Thanks.
