i2c communication between 2 pic877 problem
uav
PostPosted: Fri Aug 24, 2007 12:44 pm     Reply with quote
uav wrote:
hi i've a problem with i2c communication with following code
 master
while (1)
   while(~porta0){}
   while(porta0){}
   i2c_start(); // Start condition
   i2c_write(0x54); // Device address
   i2c_write(8); // Write Command
   i2c_stop();
   delay_us(50);
   i2c_write(0x54 + 1); // read
   [b]for (i = 0; i <7>=0x80)
    [b]portd++;
     i2c_write(0xf1);[/b]
    else if (state >0)
       portb = i2c_read();
i test these codes with protues by checking port values. At this debbuging step slave pic freezes. master demands only 8bytes from slave. but i found that slave tries to send 9 bytes to master (portd indicates 9) and i think program stuck up there. how can i solve this problem thanks for your helps.
sorry for wrong post at different topic
uav
PostPosted: Fri Aug 24, 2007 12:45 pm     Reply with quote
oops i forget slave codes
void ssp_interupt ()
{   state=i2c_isr_state();
    if (state>=0x80)
    portd++;
     i2c_write(0xf1);
    else if (state >0)
       portb = i2c_read();
