Problems with Microchip ICD2 Debug and 18F458
fedetouz
PostPosted: Thu Aug 23, 2007 10:09 am     Reply with quote
Hi, i have a problem with debug on ICD2, this is the config of the pic
#include <18F458.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=Xbee232)
    CD0083: Debug: Unable to enter debug mode. Please double click this message for more information.
    ICD0069: Debug: Unable to run target
in programing work ok, but the problem is on debug, the voltaje test its ok!.
Thanks for help!
PostPosted: Thu Aug 23, 2007 11:00 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=28960&highlight=unable+enter+debug+mode
