Drivers for the 24LC256 and FM25256 are the same..?
arunb
PostPosted: Wed Sep 05, 2007 3:03 am     Reply with quote
I have just got the FM 25256 working (FRAM ), I used a set of drivers that were posted in the Code Library in this forum and I found that it did not work, but when I used the drivers for the 24LC256 EEPROM (found in PICC folder), I was able to read and write to the FRAM.
Is it OK to use the 24LC256 EEPROM drivers for the FRAM or does it need any tweaks for better operation ???
thanks
arunb
Note: Iam using byte read and writes
PostPosted: Wed Sep 05, 2007 4:46 am     Reply with quote
They should work fine. You can slightly speed things up, by getting rid of the reading and testing of the busy status bit on the write. On the EEPROM, the code needs to wait here, till the chip is ready. On the FRAM, once the data is transferred, the write is immediately completed, faster than the I2C bus can transfer a byte.
PostPosted: Wed Sep 05, 2007 10:33 am     Reply with quote
I have just got the FM25256 working (FRAM). I used the drivers for the 24LC256 EEPROM.
The FM25256 has an SPI interface. The 24LC256 has an i2c interface.
http://www.ramtron.com/doc/Products/Nonvolatile/Detail.asp?ID=30&gr=5
arunb
RE:
PostPosted: Wed Sep 05, 2007 11:19 pm     Reply with quote
Your are quite right, the part number I have is FM 24C256 which is a I2C based device, thank you for pointing out the error.
arunb
