karthickiw
| problem in decoding remote signal |
Posted: Tue Aug 21, 2007 9:49 am |
i try below program to decode the TV remote signal, but i dont have any output from the PIC. i connect the IR out to the B0 pin of PIC
| Code: | #include<16F873a.h>
#device adc=8
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=19200,parity=N,xmit=PIN_a0,rcv=PIN_a1,bits=8,enable=PIN_C5)
INT8 Counter=0;
INT16 time[25];
INT1 Received=0;
INT1 fejl;
INT8 Code[17];
#int_EXT
EXT_isr()
time[counter]=get_timer0();
set_timer0(0);
Counter++;
IF (counter==22)Received=TRUE;
#int_TIMER0
TIMER0_isr()
counter=0;
void Check_Start_Stop()
fejl =0;
IF (time[1]<5250 || time[1]>10500) {fejl=1;Break;}
IF (time[2]<5250 || time[2]>10500) {fejl=1;Break;}
IF (time[3]<33500 || time[3]>42000) {fejl=1;Break;}
IF (time[4]<5250 || time[4]>10500) {fejl=1;Break;}
IF (time[21]<26000 || time[21]>33500) {fejl=1;Break;}
void Check_Code()
INT8 i;
For (i=0;i<=15;i++)
IF (time[i+5]<5250) fejl=1;
IF (time[i+5]>5250) code[i]='A';
IF (time[i+5]>10500) code[i]='B';
IF (time[i+5]>18250) code[i]='C';
IF (time[i+5]>26000) fejl=1;
void read_remote()
Check_start_stop();
IF (!fejl)
check_code();
IF (!fejl)
code[16]=0x00;
Output_High(PIN_C5);
Delay_us(500);
printf(code);
printf("\r");
received=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
//setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
//setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
enable_interrupts(INT_EXT);
DO
IF (received) read_remote();
WHILE (true);
please give the solution for this program... |
mskala
Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
Posted: Tue Aug 21, 2007 11:01 am |
| Timer 0 on the 16F873A is an 8-bit timer. Try using Timer 1. I don't know the specific sony remote but your algorithm looks reasonable, I see you are skipping time[0] correctly as that is where you first init the timer. |
Posted: Tue Aug 21, 2007 12:32 pm |
I'm not sure if this will print your string. Try changing into | Code: | | printf("%s \r\n", code); |
Humberto
Posted: Tue Aug 21, 2007 5:16 pm |
I would like to give you some comments:
1) Trying to decode an IR signal without some tools for debugging it is not a trivial task
for a beginner.
2) Try to be sure that the RS232 communication is working properly.
This will enable you to monitor some events and print out the contents of the related variables.
3) Try to write some code that really help you in the debugging stage. It is useless to
write "definitive code" while you still doesn´t know if something is working or not.
4) Try to wire some LED´s in the unused pins to use them as visible flags.
5) Inside the interrupt handler, you use the following code:
| Code: | | IF (counter==22) Received=TRUE; |
while you still doesn´t know if the interrupt was fired or not.
6) Instead, you could use a more relaxed test.
| Code: | | if (counter>n) Received=TRUE; |
Just to be sure that EXT_INT had been triggered n times, it will be enough in debugging stage.
Once this work as expected, write code to make a fine tune according to your algorithm.
7) It is better to use a visible flag like:
output_high(PIN_xx); and connect a LED in that pin.
8) In the main loop, add a long delay (>2000 ms) and use the printf capabilities
to know the desired variables and/or status flags.
9) Do not forget to shut down the LEDs inside main()
10) I must admit -according to your code in the main()- that you are a very optimistic man !!!
(I hope you accept this joke)
Humberto |
