Displaying data from one i/o port
lopex
PostPosted: Mon Aug 20, 2007 12:37 am     Reply with quote
Good afternoon to all.
My question is based on data processing from one external device.
I have connected my device to my demo board on the way that one wire is used as I/O wire (connected to 16F PIN ) and all data is passed thru this wire.
My goal is to set this PIN as input and then read all data from this I/O.
The amount of data passed thru this I/O is big and continues so the only way for me is to display this data on my computer using some terminal program.
How to pass this I/O data per serial port, to some terminal program ?
LpX
PostPosted: Mon Aug 20, 2007 12:00 pm     Reply with quote
Create the code for a UART with the #use rs232() statement, as shown
below. Connect your PIC to the PC with a MAX232A chip and a cable.
Use the following program to test it. The program will display
"Hello World" in the terminal window on the PC.
#include <16F877.H>
printf("Hello World\n\r");
PostPosted: Tue Aug 21, 2007 2:18 am     Reply with quote
Thank you for reply.
Can i connect serial cable to PICkit 1 flash starter kit ( dont ask why :-)), or do you suggest some other way for displaying data ?
Instead 16F i will use the 12F675.
Anyway, back to the problem.
The I/O wire is connected to our testing external device which is using the standard mobile phones protocols. My goal is to monitor all data that is passed thru few I/O ports but for start i will use just one.
LpX
