Lcd include file allowing pins from more than one port
Rod Phillips
PostPosted: Tue Dec 31, 2002 4:34 pm     Reply with quote
Hello to All,
I'm using an Olimex PIC-MT development board and it's included LCD display uses port_a for control and port_c for data. My question is - are there any include files that allow selecting invidiual pin functions rather than an entire port to drive a display. Thanks in advance for any information.
Rod
___________________________
Original Post ID: 10366
Re: Lcd include file allowing pins from more than one port
PostPosted: Tue Dec 31, 2002 4:43 pm     Reply with quote
:=Hello to All,
:=I'm using an Olimex PIC-MT development board and it's included LCD display uses port_a for control and port_c for data. My question is - are there any include files that allow selecting invidiual pin functions rather than an entire port to drive a display. Thanks in advance for any information.
Mr. Fick has got this on his page. He uses Port A for the
data, and two bits on port B for the control lines.
<a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank">http://www.VermontFicks.org/pic.htm</a>
Scroll down to where it says "LCD routines".
Original Post ID: 10368
Rod Phillips
PostPosted: Tue Dec 31, 2002 5:39 pm     Reply with quote
:=:=Hello to All,
:=:=I'm using an Olimex PIC-MT development board and it's included LCD display uses port_a for control and port_c for data. My question is - are there any include files that allow selecting invidiual pin functions rather than an entire port to drive a display. Thanks in advance for any information.
:=Mr. Fick has got this on his page. He uses Port A for the
:=data, and two bits on port B for the control lines.
:= <a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank"> <a href="http://www.VermontFicks.org/pic.htm" TARGET="_blank">http://www.VermontFicks.org/pic.htm</a></a>
:=Scroll down to where it says "LCD routines".
Thanks for the information PCM and thanks to Mr. Fick. I'm still on shaky ground and this sort of information sharing is much appreciated.
Rod
Original Post ID: 10375
